heater causing to much battery draw?
As some of you guys know I had an issue with my lights dimming and causing me to have to replace my alternator over the weekend bc of the thought of the battery getting drained! But it did it again on my way home last night with the heater on all the lights started to dim, I turned off the heater and and the lights brightened up and turn signals started working just fine like nothing happened. Any comments or advice is much appreciated. Thanks guys!
Re: heater causing to much battery draw?
bump
bump? It's only been an hour!
Check your battery connections, alternator connections, and ground connections. Pay particular attention to the grounds, I would expect one or more of them has failed. |
What year is your truck ?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
The blower motor isn't dragging or anything? If something is drawing that much a wire somewhere has to bee getting hot. Look for it
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Its not making any noise like it would be dragging the only time it does that is when i turn the a/c on full cold and fan on high and the a/c doesnt even work. I have looked at all the grounds that i could find. Can other wires beside ground get warm?
#9 | |
update us if you find anything. |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Possibly a failure in your field windings on your heater motor, might be intermittently going to ground.
yeah guys it's just when the heater runs. The turn signals and all the lights work beautifully when the heater isn't on. I'm going to check the blower motor tomorrow, I'm enjoying the day with my daughter. I'll get back to u guys.
