Old 12-28-2012, 02:37 PM   #1
chevellelover
chevellelover
chevellelover's Avatar
1967-1972 Leaf Spring Flip Kit Question
I have lowered leafs now on my 1972 Shortbed. Im planning on putting my stock leafs back in with a flip kit so i can run car traction bars. I haven't had any luck finding a 1967-72 flip kit. Are you guys using 1973-87 flip kits? any info would be appreciated. I have a rear end out of a '86 under it now. I don't see why a 1973-87 flip kit wont work but wanted to double check before i buy. Thanks guys
Josh.
1978 Trans Am 400/4speed Year One Snowflakes
1980 c10 shortbed
1999 Suburban 5/7 drop US Mags Roadsters
1999 GMC Sierra Classic 4x4-MINT
2015 Challenger Scat Pack 6.4 8 Speed
chevellelover is offline   Reply With Quote
Old 12-28-2012, 03:10 PM   #2
69gmc292
Re: 1967-1972 Leaf Spring Flip Kit Question
I used a flip kit on my truck that was from DJM. This is one that i found that shoul work on you truck.
http://www.stylintrucks.com/parts/lo...0114_3339.aspx
69gmc292 is offline   Reply With Quote
Old 12-28-2012, 10:39 PM   #3
xmitsu10
xmitsu10's Avatar
I too used the DJM flip kit but purchased form Summit Racing. http://www.summitracing.com/parts/djm-fk1012-5
I also was running dropped leafs like you but made the change to go lower and soften the ride a bit. I did need to install a c-notch kit too. Save yourself some time and in my case, money, and do both flip and notch kits at the same time. The DJM rep told me I wouldn't need the notch kit but that was incorrect. The axle was about 1" from the frame after flip kit was installed and would bottom out on any bump. Got the c-notch kit from CPP and all is well now.
Mark
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 12-30-2012, 08:45 PM   #4
Sonoma10714
Mark
Did u relocate your shocks or not?
Sonoma10714 is offline   Reply With Quote
Old 12-30-2012, 09:26 PM   #5
xmitsu10
xmitsu10's Avatar
I did not. I used KYB drop shocks with the drop leafs and am still using them with the flip kit. But I need to get even shorter rear shocks to get the best ride. It's not bad now but believe it could be better with shocks that were a little more vertical than what I currently have.
71 Cheyenne SWB
Old 12-30-2012, 09:40 PM   #6
Sonoma10714
What's the specs on your rear set up?
Old 12-30-2012, 09:47 PM   #7
xmitsu10
xmitsu10's Avatar
Rear suspension specs are in this thread. My guess is the flip kit gave me a 6" drop. Tire/wheel are 275/60/15 on 15x10 wheels. If that doesn't answer your question, let me know.
71 Cheyenne SWB
Old 12-31-2012, 12:16 AM   #8
Sonoma10714
What drop leafs are you running?
Old 12-31-2012, 07:46 AM   #9
xmitsu10
xmitsu10's Avatar
The 4" drop leafs I WAS running were from GMC Paul's. I'm not running them anymore, but running stock leafs with a flip kit.
71 Cheyenne SWB
