A/C dash vents without A/C?
I'm just curious has anyone installed factory A/C dash vents into a factory non-A/C truck, while leaving the truck strictly heater only, no A/C...
I'm asking because I like having dash vents for heat, but don't really need or want to convert my non-A/C truck to A/C.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#2 | |
Active Member
![]() Join Date: Jul 2007
Re: A/C dash vents without A/C?
An option you could consider is a small fan on the floor board?
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#3 | |
![]() Join Date: Nov 2004
My only concern is functionality... its been quite a while since i added A/C but if i recall there is only two vent hoses from the heater, with one going to each defrost vent and a slit on the bottom of the box for floor heat? You would have to tap into the hoses for the defrost vents and share the heat with the dash vents while it is in defrost... not sure how that would affect how well the defrost will work? I cant think of any other way for it to work with the stock heater only box. You wouldn't be able to split the heat ... both would be on at the same time.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-28-2012 at 04:22 PM. |
67chevyredneck, i've thought about that idea also. I've never actually seen the a/c vents first hand, do they completely close so if you wanted just defrost you could close those vents?
The other idea I thought about was maybe taking the under dash air box for an A/C truck and mounting it under the dash to allow for the proper outlets for all of the dash vents. And then leave the existing heater box on the firewall with the heater core in it... I know that might sound like a lot of work for just vents, but I'd still rather not install a compressor, evaporator, condensor, and all the other stuff that goes along with A/C.
Or better yet I could install a factory a/c air box under the dash with the heater core and eliminate the air box under the hood. But then I'm not sure what I'd do about a blower motor...
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 12-28-2012 at 08:00 PM. |
That's where I'm out of my element... I know that the cab is slightly different for the A/C trucks vs non A/C trucks, but I've never physically taken apart an A/C truck heat/air system, so I don't know how well all of that would mount up? You can always cut the box and use fiberglass and resin to "make it work"?
I have aftermarket style vents in my truck... don't know if or how well factory ones close. I think you can turn the ball so that it stops the airflow, but not 100% on that.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Yeah I've seen how one of the large holes in the firewall is different between A/C and non-A/C trucks. So an A/C box under the dash wouldnt line up perfectly with the heater box under the hood. And that was where the idea of eliminating the underhood air box came from.
I've heard that there are aftermarket A/C & heater systems that are setup with the blower motor under the dash but I haven't been able to find any pictures to show how it's done...
