brake bleeding/proportioning valve question...
Hey Guys,
I recently had a rear wheel cylinder go bad on my '72 LWB, so I replaced the wheel cylinder and put a new brake line on as well. And I was having trouble getting my brake light to go out. So, of course, I started looking for answers on here...and I found them (you guys are awesome!). But, I want to be sure that I have it right before I go out and lay in snow to fix it this weekend. To get the light out, I should open the front bleeders and pump the pedal 3-4 times and the proportioning valve should go out...and if that doesn't work (and it didn't last weekend), I should try a quick 'kick' to the pedal. Is that right? And then, I should push in the button on the proportioning valve and let all 4 bleeders gravity bleed for a bit, without touching the pedal. Does that sound right? And just fyi, when I would pump the pedal last weekend, the brake light to go off as I pushed the pedal down, and come back on as I let off. Thank for any input, guys! Chris |
Re: brake bleeding/proportioning valve question...
The way I did mine was just stomp on the pedal real hard a few times until I heard an audible "pop". All the bleeders were closed when I did it. Then I went around and bled the brakes like normal.
-Scott- |
Okay, cool. Maybe I'm over thinking it...a good, solid stomp sounds a lot easier!
Chris |
20' Daredevil (Ret)
![]() Join Date: May 2003
That worked for me also.... a few good HARD pushes on the brake pedal.
mine failed and in a panic stop stomped the heck out of the pedal and all has been fine since. I will completely this winter.
Hey Guys,
I've tried giving the brakes a few good hards pumps...but the brake light still won't go out. I also cracked the front bleeders and pumped the pedal a few times...the brake light will blink out and then come back on. So, I'm kinda looking for suggestions...could I need a new proportioning valve? Any other ideas? Thanks guys! Chris Posted via Mobile Device |
Push in the button on the front of the prop valve and keep it pushed in. Bleed your brakes from farthest rear to the front then let the button go.
#8 | |
Hey Guys,
I'm flying solo today, so I'll have to get creative to get brakes bled. Thanks so much for the input! Chris Posted via Mobile Device |
