getting ready for crossmember swap
I think i finally have all the pieces to rebuild the"new" front crossmember for my 68.
I got a crossmember from an 85 burb. All new bushings and ball joints are sitting in the shop waiting. I'm still debating on powdercoat or paint?? I' m also wondering what kind of brake line issues I'm going to have when I put it in. If anyone has advise please chime in. I'm going to break it down tonight, guess i need to decide on paint or powdercoat soon. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: getting ready for crossmember swap
Leave the '68 crossmember in your truck.
Run the rebuilt '85 a-arms and steering linkage. Use the '68 steel brake lines on the original crossmember. Bend up a couple new lines to a 71-72 M/C and prop valve. ECE rubber brake hoses. No need to change the crossmember or engine mounts.
![]() Join Date: Mar 2012
its the exact same crossmember, no need to swap it unless yours is damaged or you've turned the new one into a dropmember.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 Last edited by Square_78; 12-29-2012 at 12:07 AM. |
A day late and $1 short...
Good advice here, definitely leave the original crossmember in there! I made the mistake of swapping mine for the later model, don't do it!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
I guess if you aleady have the motor pulled out then its not that big of a deal to take it out and bolt in a new one. Its an easy way to swap in disc brakes from a newer truck. Just drop in a whole new crossmember, brakes and all in one big package.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
