![]() Join Date: Oct 2012
Which Brakes?
I see a number of different kits and brackets for converting 67-72 rear's. What are the advantages/disadvantages?
I"m assuming the number of options are based on what is most commonly available and that will fit our axles. So, for someone who intends on driving this frankenstein ('50 on a '72 chassis) often, what would you recommend I look at? Thanks in advance.
James "Bierkan" Vierkant 1950 3100 on a 1972 C10 Chassis Truck Blog Motorcycle Blog |
Re: Which Brakes?
Interested in this as well. Difference in axle width?
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
Re: Which Brakes?
For your truck (and most) the rear drums are all you will ever need. Combined with the factory front discs and a booster you should be good to go with just an overhaul. Why do you want to change and to what?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: Which Brakes?
Thinking about switching to discs. I'm an engineer and I like to tinker.
I am a Referee of life.
Re: Which Brakes?
There are a ton of threads on swapping to disc brakes.There are kits or you can use factory parts from 71-86.Use the search and you'll find lots of info on what works well.You may have to go to an aftermarket booster/MC with the early body.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: Which Brakes?
He is wanting to add rear disc brakes to a 72 C10 chassis. Does anyone make a kit that uses the old 'vett style internal e-brake shoes?
Re: Which Brakes?
Check out master power brakes, they have a great product and have great customer service
Posted via Mobile Device |
