Old 12-28-2012, 10:37 PM   #1
fastnloud
fastnloud's Avatar
Lowering my 82 Sierra
I'm looking to lower my 82 GMC Sierra c1500 4/5. Does anyone know if they used 1 inch or 1.25 inch rotors on these trucks?
Also, would it be best to do spindles and springs combined for the 4 inch drop in front instead of just 4 inch drop springs? I want to be able to get a good, straight front end alignment.
I'm going to do a 5 inch flip kit in the rear. I will be using 15x8 wheels in front with 4 inch backspacing and 15x10 in rear with 5 inch backspacing.
Thanks guys.
fastnloud is offline   Reply With Quote
Old 12-29-2012, 12:30 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Lowering my 82 Sierra
They used both 1.0" and 1.25" rotors on these trucks, and best to measure to make sure you get the right spindles. Just have to pull the wheel and measure the rotor thickness.
I would suggest 2.5" drop spindles and 2" springs. The spindles are a good way to go and will offer the best ride, since only 2" springs will be needed to make it a total 4.5" drop in front. The flip kit in the rear will work great. It will be about a 5" - 6" drop.
McGaughys has a kit that is 4.5/6 and has everything you need, including the c-notch. They are quality components at an affordable price and adding shocks is an additional $198. The kit runs $570 without the shocks.
http://www.azproperformance.com/McGa...150-93151.html
Travis
Pro Performance is offline   Reply With Quote
Old 12-29-2012, 08:24 PM   #3
fastnloud
fastnloud's Avatar
Thanks, I'm not sure If I can fit a 255/60/15 in front with a 4.5 inch drop or not.
Old 12-29-2012, 10:38 PM   #4
baclay9
I have 245/60/15's on the front of my 74'. I have 5" of drop on the front and have plenty of clearance.
baclay9 is offline   Reply With Quote
Old 12-29-2012, 11:08 PM   #5
fastnloud
fastnloud's Avatar
Thanks for the info. Do you happen to have long tube headers on your truck?
I have long tube headers on my truck, and I'm trying to figure out how low I can go without them being too low to the ground.
Old 12-29-2012, 11:12 PM   #6
fastnloud
fastnloud's Avatar
I was planning on using this 5 inch drop on the back.
http://www.summitracing.com/parts/dj...olet/model/c10
I'm not planning on notching it, I don't haul heavy stuff in my truck, and from what I've read you can lower 5 without a notch, but over that and you need a notch.
Are the red pieces pictured in that kit, shortened bumpstops?
Old 12-29-2012, 11:25 PM   #7
baclay9
You won't need notches with a 5" rear drop. Just cut your stock bump stops off.
I do not have headers. I have stock manifolds.
Old 12-29-2012, 11:28 PM   #8
fastnloud
fastnloud's Avatar
Alright thanks.
Can anyone tell me how low would be ok with long tube headers? I believe mine are hooker super comp long tubes.
Old 12-30-2012, 11:26 AM   #9
Pro Performance
Not for sure on the headers, but you won't need a c-notch if not hauling heavy stuff in the back. The c-notch included in the McGuaghys kit is just to cover all bases in case somebody does. Just extra clearance in case it is needed. With a light or unloaded bed, you will be Ok without.
Old 12-30-2012, 12:52 PM   #10
flamingbig10
6.0 powered square
flamingbig10's Avatar
how low do your headers hang below the frame
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-30-2012, 10:31 PM   #11
fastnloud
fastnloud's Avatar
I think I'll be alright when it comes to the headers. It looks like about 9-10 inches of clearance.
Also, does my rear suspension look stock to you guys?
Old 12-30-2012, 10:44 PM   #12
baclay9
Looks stock to me
Old 12-30-2012, 10:55 PM   #13
fastnloud
fastnloud's Avatar
Good, I was hoping so. Since, I just wanted to put a flip kit on and have 5 inches of drop.
Old 12-31-2012, 06:52 AM   #14
bbbc10
Diggin The SquareLife
mine is 5/6 wth 15x8 255/60 front and rear is 15x10 275/60...i used to have long tubes an hit everything wth them..i ended up getin shortys
bbbc10 is offline   Reply With Quote
Old 01-02-2013, 12:08 AM   #15
fastnloud
fastnloud's Avatar
Yeah, maybe I'll be ok just dropping 4 inches in the front. Great looking truck you got.
Old 01-05-2013, 10:20 PM   #16
fastnloud
fastnloud's Avatar
Bump.
I'd like to hear from anyone else who has long tube headers on their lowered c10, and what drop your using.
Old 01-06-2013, 10:00 PM   #17
fastnloud
fastnloud's Avatar
I've noticed that depending on where my truck is parked, changes how much clearance I have between the headers and the ground. I was measuring today on a fairly flat surface, and it looks more like 6.5-7 inches of clearance.
Old 01-30-2013, 11:51 PM   #18
marco67
I have a pair of 2" front drop springs, (less than 200 miles on them) looking to swap for stock coils.
where are you located?
marco67 is offline   Reply With Quote
Old 01-31-2013, 04:03 PM   #19
marco67
if you part with the front coils, I'm your guy
thanks
Old 02-01-2013, 03:06 PM   #20
holyroller69
holyroller69's Avatar
thanks
Got some stockers out of a 76 if your interested in trading up?
holyroller69 is offline   Reply With Quote
