Old 06-07-2003, 11:47 PM   #1
MStokes
MStokes's Avatar
Blazer Tank Install Question
I just purchased a 21 gallon Blazer tank from GMC Paul's to put in the rear of my 72 C-10. I have already cut out the small cross-member for the spare and should be ready to drill holes to mount the new tank. The main questions I have are:
The two straps that came with the kit have the ends bent different directions. How exactly is this meant to connect to the frame.
Each of the two short sides of the tank have a wedge shape that is flat on the top. Is this meant to mount flush to the bottom of the frame?
Will I have to cut the bed cross-member before I put the bed back on.
I don't have my digital camera with me or I would have posted some pics to make it easier to see what I am talking about. The kit came with absolutely no install directions.
Thanks in advance for any input.
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 06-08-2003, 12:31 AM   #2
00droptopSS
2.5/4 on 20's
00droptopSS's Avatar
I just installed mine last week and I will post pics tomorrow. I left my digital at work.
I just bent one of the straps to match the other. I also folded the eye hole end of the strap over and redrilled the hole to shorten the strap by about an inch. I installed mine with the bed off.
I'm trying to get the tank as high as possible, now I'm wondering if I'm going to have to notch my bed cross bar to fit over the tank. I may have gotten mine to high by using the top of the wedge on the bottom of the frame.
I plan on setting the bed on the frame Monday to see, but if it is to high I plan on notching the bed. It will be some metal work, but a cool custom touch never hurts.
MStokes: where are you putting your fuel door?
62 C/10 SWB. Currently in ground up resto. Big back window cab, V8, auto. My wife's grandfather's truck.
1965 Mustang Vert - Shelby Clone
2005 Dodge SRT-10
My Old 72 SWB
00droptopSS is offline   Reply With Quote
Old 06-08-2003, 01:12 AM   #3
MStokes
MStokes's Avatar
Pictures would be great droptop. There are a lot of posts on the board dealing with opinions on moving the tank or not, but not a lot of details on the exact mounting of the tank.
Right now I am leaning towards running the filler through the wood bed floor and mounting it flush in the bed. I have a long ways to go though before I have to make a decision. Attached is a photo of the current state of my truck. Along with the gas tank kit, I just got all the front end suspension and steering parts I need to get the front end together
Old 06-08-2003, 01:17 AM   #4
MStokes
MStokes's Avatar
Too fast on the mouse button. I got to looking at the options to post an attachement and it doesn't look like it is going to let me do it from home.
Old 06-08-2003, 01:19 AM   #5
bpmcgee
bpmcgee's Avatar
The wedge-shaped notches are the support that is used to hold the tank in place -- the straps will push those two wedges up against the bottoms of the frame rails.
I know this, because I just installed the identical tank today in my 71 blazer! Whoo hoo! Only 3 more wires to my TBI system!
Brian
bpmcgee is offline   Reply With Quote
Old 06-08-2003, 10:18 AM   #6
Low69CST
I went though this whole installation. www.low69cst.freeservers.com/blazertank.htm
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-08-2003, 10:52 AM   #7
72MARIO
72MARIO's Avatar
Pic's cant be posted till friday.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-09-2003, 03:28 PM   #8
00droptopSS
2.5/4 on 20's
Blazer tank
I added pictures of the tank installed. They are in my link in my sig.
2005 Dodge SRT-10
My Old 72 SWB
Old 06-09-2003, 03:51 PM   #9
Jwill41
Jwill41's Avatar
I installed mine the same way. There is not enough room between the tank and bed floor for a filler to connect. There is not even room for the marine filler less the hose for the connection. What did I do wrong? I was hoping to come straight up in the bed floor.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 06-09-2003, 04:50 PM   #10
Custom 68
Custom 68's Avatar
Hey 00droptop is that a poly tank or a metal tank? It seems there are different "blazer" tanks.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-09-2003, 09:27 PM   #11
00droptopSS
2.5/4 on 20's
tanks
Custom 68: It is a 21 Gal. Blazer tank from GMC Pauls.
I thought of doing the stainless tank thing, but for my daily driver I think the Blazer tank is a better choice.
I'm saving the high dollar tank for my next project. I'm going all out on the next one.
2005 Dodge SRT-10
My Old 72 SWB
Old 06-10-2003, 12:20 AM   #12
Custom 68
Custom 68's Avatar
00droptop
Thanks but he has both the poly and steal. yours looked to be the black poly one is that correct?
Dave
Dave
Old 06-10-2003, 10:05 AM   #13
00droptopSS
2.5/4 on 20's
Good point. It's poly.
2005 Dodge SRT-10
My Old 72 SWB
Old 06-10-2003, 10:08 AM   #14
72MARIO
72MARIO's Avatar
You can bend the filler neck if it is a poly tank. Just use a heat gun and heat the base around the neck. I used a big socket that fit over the neck and a 12 inck exstion for leverage.
Hope that helps some one out.
2005 TAHOE DD
Old 06-13-2003, 11:17 PM   #15
MStokes
MStokes's Avatar
Thanks for the extra photos droptop. I just got home this evening after being gone all week. I'll try to take a closer look at mine this weekend if I get a chance.
I was thinking the straps were meant to run parallel to the axle. It looks like you ran them the other way?
Anyone else with comments on the amount of bed cross member that has to be removed?
It looks like the board will let me post a photo now so I'll give it a try.
Old 06-14-2003, 10:18 AM   #16
00droptopSS
2.5/4 on 20's
I think the straps are intended to go side to side, but I just prefer the front to back mounting. It appears to be fine that way.
Nice looking frame. Your off to a good start.
2005 Dodge SRT-10
My Old 72 SWB
