12-29-2012, 04:42 PM | #1 |
Replaced almost every heater component. Cab is blistering hot now
My truck didn't even come with a heater core. Bought a new one and installed it along with all new hoses, radiator hoses, and radiator fluid, only to find that my blower motor bearings were going out, and it was making a huge racket and wasn't blowing at full speed. Then, the face to the heater control snapped off at the rivets, and I couldn't control it very well. Found a nice replacement at the junk yard for $19. Then, it was time to change the blower motor. Found a brand new one at Autozone for $21. Got that installed, and here's where the bazaar thing starts...
Turned on the blower, and it's really blowing hard. Turn it off, shut the hood, and take it for a spin. As I'm ready to back out, the heat stops blowing! I'm like WTF! I park, and look at the fuse panel. Sure enough, the fuse blew. Here's the weird part. It calls for a 25 amp fuse, but the PO installed a 10 amp fuse! No wonder it blew. And, it only lasted this long, because the old motor was almost shot and couldn't blow at full speed. I buy the correct fuse, install it, and all is well. Very hot! Posted via Mobile Device |
12-29-2012, 04:52 PM | #2 |
Re: Replaced almost every heater component. Cab is blistering hot now
I'm lead to beleive the Heater cores get blocking in then from time to time. I might have to take mine out and flush it or replace it also....
It does not leak but its not real hot either.....
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-29-2012, 05:02 PM | #3 |
hey ol skool try reversing your heater hoses to use the other side of your heater core. had the same problem a few years ago wasn't getting very hot. and old mechanic told bout changing the flow of the water to the core worked great for me.
12-29-2012, 06:36 PM | #4 | |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-29-2012, 06:54 PM | #5 | |
Oh well.....
12-29-2012, 07:05 PM | #6 |
20' Daredevil (Ret)
ol_skool_chevy -- Dunno about your heater hoses, but mine are different sizes so are not made to be reversed. Reversing the hoses would only reverse-flush the core anyway, and you already flushed out your core so it should be good.
The hot water needs to flow into the core at the lower nipple, and out at the upper nipple. Not only because heat rises, but also to help purge air from the system. If your core is good and the rest of the system is up to snuff, you'll have good heat.
12-29-2012, 07:34 PM | #7 | |
its HOT now
12-29-2012, 07:36 PM | #8 | |
Also, this new blower blows out MUCH harder then the old one. When I first turned it on, I actually got leaves and debris blow out that the other blower didn't blow through Posted via Mobile Device |
12-29-2012, 07:50 PM | #9 | |
If you have an ammeter it would be interesting to see how much that motor is drawing. Your old dying motor could have weakend the fuse through repeated thermal events to a point that the new motor overloaded it.
12-29-2012, 07:50 PM | #10 |
Mr B, I have a heater only set up and my blower is very weak too. Did you already have a part # for the blower motor when you went into Autozone or did you tell them your set-up and they fixed you up? I may just take out my heater core and see what comes out of it with a flush job. Congrats on the fix and thanks all of you who have contributed.
Dan |
12-29-2012, 08:25 PM | #11 |
Heck,I have driven these trucks forever and it's rare that I ever use the fan or put the controls past 1/2 way. I never wear a jacket in the truck,either. These things have killer heat and the only time I use the fan is to defrost/de-ice or drive with my window open when it's cold. I'd run a 10 fuse if you don't have A/C.
12-29-2012, 08:31 PM | #12 | |
12-29-2012, 08:34 PM | #13 | |
12-29-2012, 08:36 PM | #14 | |
12-29-2012, 08:43 PM | #15 | |
This new motor IS a bit longer. I only noticed, because getting the hood bracket back on was more difficult, and I had to use a different wrench because the other wrench I used to get the hinge off didn't fit anymore Posted via Mobile Device |
12-29-2012, 08:58 PM | #16 |
I am a Referee of life.
Just aheads up.Some of the newer heater cores use a smaller diameter tube,I have to unhook the one in my Dakota about every 2-3 years and flush it both ways with the hose.Otherwise it tends to clog and not heat well.These have a larger tube but probably still would slow over time.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-29-2012, 09:11 PM | #17 | |
Like Special-K said you should keep the fuse down to a 10A unless the motor draws about that then it might need to be stepped up some. The 25A fuse that replaces the 10A is also powering the compressor clutch circuit as well in a A/C (C60) equipped truck.
12-29-2012, 10:11 PM | #18 | |
The one right below it was never touched or blown. I assume it was a 10 amp, but I guess I don't know 100%, since I didn't have to change it Posted via Mobile Device |
12-29-2012, 10:27 PM | #19 |
I remeber the heaters being real strong back on the farm in the 60's and 70's also, so it's something I need to look into. I think I've gotten enough info from this discussion to take it on when I get a chance. Thanks everyone.
Dan |
12-30-2012, 08:31 AM | #20 | |
He should try a 10 amp again since he only has a heater system and not an A/C system. If it blows another 10 amp fuse then is his new blower fan pulling to much juice?
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! |
12-30-2012, 10:01 AM | #21 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
12-30-2012, 06:18 PM | #22 |
Good info. I noticed my heater sucks in my truck, it gets lukewarm if I sit at idle, but it cools off as I drive. Both hoses going into the heater core get hot, must be plugged up on the inside or just need to be replaced. Gotta love the internet!
12-31-2012, 10:17 AM | #23 |
Yes,or some other issue,like a short. It's like this: There is one fuse location for heat. If you have the A/C system you run a 25A and if you have a non-A/C system you run a 10A. If you run a higher amp fuse than called for you are unprotected at the amperage the unit is designed to operate within. Putting a higher amp fuse in can prevent blowing the fuse but negates the purpose of the fuse as a safeguard against burning something up
12-31-2012, 11:40 AM | #24 | |
12-31-2012, 11:40 AM | #25 | |
20' Daredevil (Ret)
. . . . . . . . . . OK, I hope everyone here recognizes tongue-in-cheek humor when they see it.
