![]() Join Date: Mar 2002
waht to strip from I6 to use with V8?
I just pulled my I6-250 to swap in a V8-350. don't have the SBC yet, so....
what accessories, brackets, etc. should i remove from the I6 because I will need them for the V8? plan to sell or give away the I6. engine mounts? flexplate? starter? power steering? thanks, tom |
![]() Join Date: May 2007
Re: waht to strip from I6 to use with V8?
All the brackets are different. If you decide to give away or throw away let me know I'll come and get it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Nov 2004
Actually, if you want the V8 mounted in the "correct" position you will need a set of V8 engine stands as well (part that bolts to frame and crossmember). Plenty of guys have put their v8's in the I-6 position but the motor will sit farther back and if you run HEI it will be pretty close to the firewall. Are you sticking with the trans that's in it? Not sure how moving/not moving the engine stands will affect that.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
RUbber engine mounts, flexplate and bolts, starter, alternator, oil and temperature sending units.
#5 | |
My blazer is a 4X4. From what I have been told, Chevy had the engine close to the firewall on these 4X4 trucks. Sticking with the sm465 and np205. Although I would like to move the V8 forward, I think shifting the engine, tranny, and transfer case forward would cause problems with the front. driveshaft . Do I have this wrong ?
#7 | |
Chemist under the hood...
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
#8 | |
Posted via Mobile Device |
#9 | |
Thanks, makes sense now that you mentioned the obvious. Guess I forgot to mention I pulled the body off the frame, wire harness off the body/frame, so I sort of left the harness move with the engine. I'll keep the harness to re-install if I don't buy a new harness.
Tom Quote:
