12-29-2012, 06:12 PM | #1 |
some snow pictures of my '66
Have a little snow storm going on here in the garden state and i figured I'd snap a couple pictures.
12-29-2012, 06:30 PM | #2 |
Re: some snow pictures of my '66
mine did not leave the barn. no snow on this truck[IMG][/IMG]
12-29-2012, 06:50 PM | #3 |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-29-2012, 07:00 PM | #4 |
it's snowing here in branchburg , i dont no how you let your truck sit out like that.
12-29-2012, 07:03 PM | #5 |
Who Me?
Someone left a matress on your hood!
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
12-29-2012, 07:26 PM | #6 | |
don't worry there's plenty of wax on the paint and polish+wax on the chrome. i really wish i had a 300 dollar beat up car to take out, but it would defeat the purpose of having a truck when it still is going to sit out in the weather no matter what. i like these older cars too much than to just have one, so i bought the truck to daily drive. i know some of you think i should be shot, but you only get one shot to enjoy the classics, and why not start young. it was a one owner since '67 just 93k miles ALL original truck with not a spec of rot, it does kill me believe me., I'm nuts you can say it haha. |
12-29-2012, 07:59 PM | #7 |
I recommend a Costco Carport for a little over $200.
12-29-2012, 08:59 PM | #8 |
having a few of these trucks over the years up here in the northeast that have been left out in the elements i know a few things to aid the watershed in a few areas,first is the drip rails.all of mine although aged seemed to be lacking enough seam seal in them from the factoryand what is there is hard and cracked.dig it out and seam seal again covering completly the spotwelded metal seam and banking it high on the outer edges.,clean out drains.
second is the hood front edge holds water.afew holes to drain in the right places .a q tip with a good oil base paint to cover the open metal in your holes. third ,the area where the cowl ,fender and inner fender meet by the hood spring.water settles there to ,best to look at it while wet and youll see where weep holes are helpful .lastly the antenna hole up behind the glovebox.hope this helps. and yes i am biased |
12-29-2012, 09:19 PM | #9 | |
Wouldn't wax be just as efficient? as long as its just pooling water it'll just rest above the actual sheet metal. I'll have to check under the dash under the glovebox and see where your talking about if you've got pictures illustrating where you're talking about that would be sweet! |
12-29-2012, 09:25 PM | #10 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-29-2012, 09:40 PM | #11 |
plus who knows how much longer we'll be able to drive these older vehicles! My truck is all original, and its going to stay primarily original, except some nice cosmetic add on's that improve on its already good looks, nothing gets sold or thrown out. sheet metal replacement is really the only thing i will dread having to do it it. i hope it takes a LONG time before i have to worry about it.
12-30-2012, 01:06 AM | #12 |
60-66 Nut
My advise to those that drive their trucks in the snow and ice, is to do your best to keep them washed. Not just on the outside, but underneath as well. The de-icer, be it salt, mag chloride or whatever, is the most damaging to these older trucks.
12-30-2012, 01:18 AM | #13 |
well i agree but its just as corrosive to a newer car it just takes longer nowadays to rot them out it seems. water pressure can only get so much salt/de icer off.
12-30-2012, 01:24 AM | #14 |
60-66 Nut
I agree. I have heard that soap will help neutralize the de-icer.
12-30-2012, 01:31 AM | #15 |
any idea's as to what kind of soap?
i may have a shop undercoat the truck locally it costs quite a bit last time i remember $800 bucks but it'll save the underneath of the truck in the long run |
12-30-2012, 06:46 AM | #16 |
my 66 is a semi daily driver , except when it rains and snows , then i use my car in bad weather . the wife gets mad because she cant get her vehicle in the barn cause i have my 1965 gmc truck in there also ,and there's no more room. that truck is getting restored as we speak. [1965 gmc, k1500, 4x4 , 305v6, 14,500 miles].
12-30-2012, 09:14 AM | #17 | |
1964 BBC 402 4x4 |
12-30-2012, 07:09 PM | #18 | ||
In fact, those chemicals are the only reason why I don't drive my older vehicles in the winter. The roads around here are loaded with salt and it seems to wick it's way up into all the pinch weld seams and boxed in areas on the underside of a vehicle where it's nearly impossible to completely wash out. And they spread a salt & sand (actually gravel) mixture on a lot of the town & secondary roads. It helps with traction when the roads get coated with packed snow and ice but it also causes a lot of rock chips. Quote:
By the way yellow400ex05 & harpo1313, your trucks both look a lot like my dad's 66 Last edited by ray_mcavoy; 12-30-2012 at 07:16 PM. |
12-30-2012, 08:00 PM | #19 |
Moderator
