12-30-2012, 11:45 AM | #1 |
crew cab door hinges ????
i got a 1966 "armbruster" crew cab ,it is a 3 door ,the left rear door is just screwed,bolted in place ! would like to put hinges on that 3rd door ! what hinges are they? look almost like " panel truck " rear door hinges ?thanks mike "carryallman"
12-30-2012, 04:44 PM | #2 |
Re: crew cab door hinges ????
I know the suburban lower rear gate hinges are really similar to the regular front door hinges, and the pins and bushings are exactly the same. I'd bet they are robbed from some source in GM-either panel rear doors, burb gates, even might be from a car or van in GM's lineup.
12-31-2012, 07:59 AM | #3 |
The rear suburban/panel hinges actually go thru the exterior sheet metal of the doors. I'd look at something like the side door hinges from a mid-60's chevy van. They are also an exposed hinge, but bolt on to the jamb and the door going thru a notch cut in the outer skin.
Just a thought without pictures to see what you have on the other side. |
12-31-2012, 09:46 AM | #4 |
1961 crewcab
curious to see what you turn up. I would love to know the coachbuilders source for the hinges as well....
I wonder where the catch strap came from as well? pics in case anyone recognizes them...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-31-2012, 11:48 AM | #5 |
jonz -- those look similiar,to me anyway, as to what I have on my suburban rear barn doors, especially the way they go thru the outer door skin and use recessed bolts.
Just my take on it. |
12-31-2012, 05:50 PM | #6 |
I agree with Tincan... My first thought was they look just like the lower hinge on my '61 Suburban.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
01-01-2013, 08:53 AM | #7 |
thanks for all the help guys NOW i need to go out and check some trucks ???? i sure need to get that back drivers door so it opens !!!!
01-05-2013, 02:25 PM | #8 |
Re: crew cab door hinges ???? NEED SOME !
has anybody got a set of hinges for my left rear door ? need them bad ! there should be a bad or too rusty cab out there somewhere ? thanks mike
