It's all in the timing
Removed Bed
I removed the bed yesterday on my truck and was wondering if their is supposed to be any type of cushion between the bed and frame.Classic Parts of America lists bed mounting pads on their site,rubber pads between frame and bed.Mine was only riding on a washer.http://www.classicparts.com/1954-87-...ctinfo/13-556/
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
Re: Removed Bed
You can order a shim pack from most suppliers (rubber 1/4" thick). Most of these trucks list a pinch. I used the shim pack and made some "adjustment" shims with an old inner tube. Lined things up perfect.
Re: Removed Bed
I dont know the answer to your question but IMO unless you are building a 100% original show truck I would put rubber betweent the frame and bed regardless if it was there originally. Metal to metal contact cannot be a good thing over time.
![]() Join Date: Nov 2004
Re: Removed Bed
Have the cab mounts been replaced? The previous owner might have noticed the cab/bed didn't line up (cab was low from old bushings) so they removed the rubber to drop the bed a tad, or they removed the bed and didn't know rubber was supposed to go there...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
![]() Join Date: May 2010
Re: Removed Bed
My 69 never had any pads between the bed cross sills and the brackets on the frame. It has a wood floor. I don't know if the steel floor beds used pads, but I doubt it. I would think metal to metal contact would improve grounding also.
Re: Removed Bed
From what I understand, the bed mounting pads were never there from stock. They are an aftermarket addition only. I have probably taken apart 15 or so of these trucks over the years and never come across them.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
Cruzin
Re: Removed Bed
I agree with above, if you use them make sure the bed has a good ground
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
My bed has a noticeable list at the very rear of the truck. The driver's side rear corner is almost an inch higher then the other side. Now up at the cab the passenger side is a tad lower than the driver's side - so there might be some twisting that pronounces the difference. I've looked under there and there are no shims anywhere - it's all frame contact. SO... I haven't tackled this yet but I'm scared there might be a little twist to the frame or a rear frame horn behind the axle - because the running gear appears to be true.
My question is: If I remove the bed and in the absence of an obvious problem that is causing this, I just shim the bed to make it level.... does that make me a bad person? |
Junior Member
Re: Removed Bed
The stepside bed I bought for my '67 had rubber pads in the bag with the bolts and such so we used them when we put the bed on.
Also there was a ground wire on the underside of the bed that I hooked to the frame.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: Removed Bed
Thanks for all the responses.The reason I removed the bed was to replace my trailing arm bushing and clean up the frame.All the body bushings and track bar bushing are done already.I'm going to find some rubber washers and run a ground wire like Shyguy suggested.
