![]() Join Date: Oct 2012
Bucket seat question
What is the difference (if any) between truck bucket seats and blazer bucket seats?
Also, differences in the consoles, seat belts, anything else? Thank you. |
Moderator
![]() Join Date: May 2007
Re: Bucket seat question
Nothing, other than the passenger mounting brackets. The blazers also had plastic covers on the backs.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
If you are planning on adding bucket seats as I suspect, here is a lot of good reading on the subject. Don't forget the floor reinforcements.
http://67-72chevytrucks.com/vboard/s...d.php?t=516328
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
good info, thanks Tim!
![]() Join Date: May 2010
As noted above for the seats.
To answer the other 2 questions... The consoles are the same, but I believe the Blazer belts are different, at least on the outboard belts. Those I've seen mount to the floor differently and do not utilize the truck style boots over the retractors. |
#6 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
More good info, Thank you guys.
