Old 12-30-2012, 10:21 PM   #1
Survivalist45
Survivalist45's Avatar
Brrr!!!
Okay, its cold... the heat in my truck works just fine, but there is only the single floor vent, which doesnt do much but keep my steel toe warm... is there any mods or tricks I can do do get more heat in the cabin?
-CJ-
69 GMC stepside
350 370HP
TH350
4:11's
8MPG and proud!
Survivalist45 is offline   Reply With Quote
Old 12-31-2012, 08:55 AM   #2
mrein3
mrein3's Avatar
Re: Brrr!!!
About all you can do is take apart the box where the heater core is. Make sure it isn't packed with debris from some friendly pack of mice, and put it back together. Not the most pleasant of jobs but if its full of stuff you won't get much heat in the cab.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-31-2012, 09:13 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Brrr!!!
These heaters work pretty good in the trucks when they are cleaned out. I run my defrost lever half way between defrost and foot level.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
