Old 12-31-2012, 03:34 AM   #1
DBear
DBear's Avatar
which rear end '74 3/4 CC
Does anyone know what rear axle came on a 1974 Chevy 3/4, 2wd crew cab with 3.73 gears? Would it be a 14 bolt FF? Thanks in advance!
DBear is offline   Reply With Quote
Old 12-31-2012, 03:39 AM   #2
bk2life
Re: which rear end '74 3/4 CC
yes it could be.
do you have a pic of said axle? its alot easier to ID with a pic.
bk2life is offline   Reply With Quote
Old 12-31-2012, 08:02 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
http://coloradok5.com/axleguide.shtml
GM CORPORATE 14-BOLT
The "small" GM 14-bolt has a 9 1/2-inch ring gear diameter. It was used in the rear of 1964-and-later GM pickups, and in the rear of 1984-91 3/4-ton Suburbans.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-02-2013, 08:34 PM   #4
Your41Plague12
Your41Plague12's Avatar
Should be a FF 14 bolt with a 10.5" ring gear; NOT to be confused with the 14 bolt SF with a 9.5" ring gear that was used in 80's 3/4 tons. The 70's 3/4 tons and all one tons used the axle you probably have.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
