Old 12-31-2012, 11:27 AM   #1
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Suspension questions
Do any members of this forum know of anyone who has moved the front shocks from outside the spring to inside the spring or if it is possible?
Lokks like it is to me.
It seems like doing this would correct the angle of the stock method...
Does anyone know of quality, geometry correcting upper and lower A-arms for our trucks? (63-66)
And my last question...
I have seen photos of sway bars on our trucks that have bushings with grease fittings on them. Anyone know who makes those?
Thanks in advance..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 12-31-2012, 12:06 PM   #2
64shortbox
64shortbox's Avatar
Re: Suspension questions
Not sure about the shocks but I would like to know this too but here's a link about greasable sway bar bushings.
http://www.google.com/shopping/produ...ed=0CFUQ8wIwAA
As far as getting more caster on your truck, you could always do what your neighbor Steve B. on his 61 Pontiac wagon. He just cut the upper A arms and moved the ball joint 2" forward. I do know someone either here or on the HAMB site made their own tublar A arms and did post pictures & instructions as to how they did it. I'm sure I saved the link but I'm not on my home computer, I'm currently in Phoenix with family.
64shortbox is offline   Reply With Quote
Old 12-31-2012, 01:04 PM   #3
kieth
kieth's Avatar
Thanks in advance..
SOME ONE JUST DID A HOW TO ON MOVING THE LOWER CONTROL ARM FORWARD 3/4" TO ALLOW MORE NEGATIV CASTER.......IT WAS PRETTY SIMPLE THEY JUST FLIPPED THE ROD OVER, DRILLED THE HOLES OUT 3/4" FARTHER FORWARD OR BACK AND REINSTALLED IT. DO A SEARCH .....IT WAS JUST LAST WEEK THAT I SAW IT. KIETH
kieth is offline   Reply With Quote
Old 12-31-2012, 01:07 PM   #4
66-PMD-GMC
66-PMD-GMC's Avatar
Cool Beans!
Those are the bushings I couldn't find....
I have have known Steve since high school...
I installed a sway bar on my 66 and it helped but it still drives like and old truck.
My 97 rides like I'm on a cloud on the freeway compared to the 66 beating my kidneys to death.
Comparing cornering between the 66 and 97 shows they are worlds apart in performance.
I have toyed with the idea of grafting a late model front clip onto a 63-66 frame but I don't want to get that deep into it.
I have the front suspension off a customers truck and see, maybe for the first time, that the shock location is less than effective.
I went to see some A-arms that a guy had on C/L and they were pretty cheesy...
Maybe I just need to play around with this and see what I can come up with on my own.
I would rather buy something than spend days building something...
Projects..
440CID 2X4 Pontiac
Old 12-31-2012, 01:10 PM   #5
66-PMD-GMC
66-PMD-GMC's Avatar
I didn't find it .... it was posted on the 60-66 message board.
Projects..
440CID 2X4 Pontiac
Old 12-31-2012, 06:23 PM   #6
theastronaut
theastronaut's Avatar
Here's the thread on the dimpling the LCA shaft for more castor.
http://67-72chevytrucks.com/vboard/s...d.php?t=501241
CPP's tubular arms correct the suspension geometry and have good reviews. They're probably the most economical arms too.
Uppers- http://www.classicperform.com/Store/...TCA-UKB480.htm
Lowers- http://www.classicperform.com/Store/...TCA-LKB481.htm
If you're into making the truck handle better then the "Make it Handle" thread in the Suspension forum will be of interest to you. LOTS of info on improving suspension geometry, shock mount locations, sway bar options, how to tune the suspension, better than stock alignment settings, etc.
http://67-72chevytrucks.com/vboard/s...d.php?t=419251
theastronaut is offline   Reply With Quote
Old 01-05-2013, 12:03 AM   #7
66-PMD-GMC
66-PMD-GMC's Avatar
Can anyone tell me who might make bolt in static coil over suspension parts?
I talked to a guy in California that sells a kit but he won't sell partial kits, it's all or nothing with this company so I guess I need to find someone who will sell me what I want/need.
What I need is a coil over bolt in front suspension consisting of the cross member, control arms and coil over shocks and hardware.
I already have brand new stuff like a steering box and associated steering linkage and also have the spindles and brakes etc.. etc...
I am not converting to rack and pinion and don't want to since all of the stuff I have is new.......
Tried CPP and a few other I have found doing internet searches but I am turning up nothing.
Any ideas out there??
Projects..
440CID 2X4 Pontiac
Old 01-05-2013, 12:26 AM   #8
66-PMD-GMC
66-PMD-GMC's Avatar
Just found this build on the forum.....
http://67-72chevytrucks.com/vboard/s...d.php?t=534956
Very informative..
Thanks for the links theastronaut..
Tha handleing thread helped...
Projects..
440CID 2X4 Pontiac
Old 01-05-2013, 12:38 AM   #9
blazins10
blazins10's Avatar
doesnt porterbuilt make a coilover dropmember ?
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 01-05-2013, 08:37 AM   #10
66-PMD-GMC
66-PMD-GMC's Avatar
I know they make a dropmember static suspension.
In my case I do not want a dropmember as I am not drasticly lowering the truck.
Their website doesn't show what I am looking for but I suppose I could go by and see what else they offer.
Projects..
440CID 2X4 Pontiac
Old 01-05-2013, 09:04 PM   #11
66-PMD-GMC
66-PMD-GMC's Avatar
went to the porterbuilt site... found a posting called sneak peak DM mild coil-over.. looks like it could work but it has been in "testing" stage apparently and for quite a while...
I would like to get something going for my 63 quarter mile truck.
Projects..
440CID 2X4 Pontiac
Old 01-06-2013, 01:53 AM   #12
Captainfab
60-66 Nut
I don't know if this is what you may be looking for, but I thought I'd throw it out there for you to have a look.
http://67-72chevytrucks.com/vboard/s...light=coilover
Old 01-06-2013, 02:10 AM   #13
66-PMD-GMC
66-PMD-GMC's Avatar
Yeah, I found that link.... cool stuff.. may have to copy that if I can't find somethig to buy...
Projects..
440CID 2X4 Pontiac
Old 01-08-2013, 12:12 AM   #14
64shortbox
64shortbox's Avatar
Here's a link on 63 - 66 tubular A arms I just found today.
http://c10forum.com/forum/showthread.php?t=27
Old 01-08-2013, 12:47 AM   #15
66-PMD-GMC
66-PMD-GMC's Avatar
Hey thanks for the link.
Those arms are for bags. I am not running bags on my race truck or they would be on my "to buy" list.
I may consider them for my wifes 63 build.
Projects..
440CID 2X4 Pontiac
Old 01-08-2013, 09:24 AM   #16
66-PMD-GMC
66-PMD-GMC's Avatar
Thanks in advance..
I am getting great advise and links from the subscribers on this forum. So Cool.
Just though I should reiterate what it is I am looking for regarding my Pro-street truck.
I want to put a static coil-over front suspension on my 63.
I thought about using the stock cross member but realized it will be a real fabrication chore to do this.
I also want to clean up the geometry, if possible, while I make the change.
I am not considering air-springs for this build.
The frame is sitting, ready for me to continue and I have a lot of new parts already like all new steering parts, spindles, rotors and more.
So now, with the help of many other members advise, I have narrowed down my needs to a coil-over cross member, control arms for coil-over suspension and the coil-over shocks and associated parts.....
With the parts mentioned here I can have the truck sitting on 4 M/T sportsman radials in a day.
Projects..
440CID 2X4 Pontiac
Old 01-08-2013, 12:13 PM   #17
LVPhotos
LVPhotos's Avatar
I would talk to the guys at PorterBuilt first to see if they can help, they are right there. Or No Limit in CA.
LVPhotos is offline   Reply With Quote
Old 01-09-2013, 02:51 AM   #18
lilbeckk
Try talking to Justin at Scott's Hot Rods out of California. My dad got a bolt in crossmember with coil overs, but i think it does have some lowering in it, I can't remember. They may be able to make one for what you need. Our truck isn't done yet but it looks well made and wasn't that hard to install.
lilbeckk is offline   Reply With Quote
Old 01-09-2013, 06:52 AM   #19
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
if it is to be a drag truck why not go with a straight front axle?
Old 01-09-2013, 09:43 AM   #20
66-PMD-GMC
66-PMD-GMC's Avatar
Scotts isn't that flexible. I called and they sell a unit and won't sell only part of the unit. They also won't (or can't because of whatever reason) delete the R&P. It was pretty much, here it is, take it or leave it.
The unit you have pictured does not have truck spindles. I have the front suspension (stock ctrl arms and cross member) and all new hardware. IF I do anything I want to use as much of what I have allready. This coil-over idea of mine is an after thought and I am trying to see what is out there and 90% of what I have found so far is for the lowering crowd. The truck sits, as it is now, on stock suspension I mentioned with the only mods being lowering springs and spindles.
I did go back to Porterbuilt and Dave was nice enough to spend nearly an hour showing me several routes I could take on this truck. I am still looking around to see what is available but I may have no choice but to go with ctrl-arms and shock relocation to get the action I want from the front suspension.
Now that is a look I hadn't thought of for my truck... the gasser look.. LOL
Oh, and another goal on this truck is to have it ready for the Hot Rod Power Tour in June.......
Projects..
440CID 2X4 Pontiac
