12-31-2012, 01:13 PM | #1 |
Air ride question
where can i get a rear air ride set up for a 82 c30/srw i want it to lay frame but cant find any c20/30 specific stuff
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
12-31-2012, 02:30 PM | #2 |
Re: Air ride question
Air ride tech sells(or use to) and HD kit for duallys but it wont lay out without modifying....check with porterbuilt they may have a rear kit available now...i just built mine wasnt to hard
Posted via Mobile Device |
12-31-2012, 08:36 PM | #3 |
the have a rear now too. said it was 1500 for bags and all.
12-31-2012, 08:39 PM | #4 |
what did you do to the front and does it lay frame right now?
12-31-2012, 08:47 PM | #5 |
My dually is about an inch and half from layin out in the front....rear lays out....front just has 3 inch spindles, top plates and i just flat plated the lowers....if it goes any lower than it is now ill have to remove or raise the Blower/air box from the firewall...i like the air/heater better than the frame on the ground....when i body it next year ill swap to Vintage air and recess the bag into the lower arm
12-31-2012, 09:20 PM | #6 |
Would you be intrested in building mine to lay frame?
12-31-2012, 09:24 PM | #7 |
I don't want to body drop just lay frame
12-31-2012, 10:33 PM | #8 |
Man if i had the time and space i would but im kinda shopless at the moment atleast till around April-May
12-31-2012, 11:56 PM | #9 |
I am in no hurry I acctually workin on another truck.
12-31-2012, 11:59 PM | #10 |
It will be a couple months before I could afford it. Let me know though.
01-01-2013, 01:19 AM | #11 |
If you can weld http://www.scottshotrods.com/4link.asp The front nate makes a dropmember for a c30 now so your covered there.
01-01-2013, 01:25 AM | #12 |
No pricing?
01-01-2013, 07:08 AM | #13 |
you can lay the front of your dually out with stock spindles/stock control arms (need pie cut) on stock size 16 in tires, with a front Z. you will have crazy negative camber when aired out.
if you can weld and can cut your front suspension off and weld it back on square, it costs about 200 dollars to lay the front of a chevy truck out and be able to air back up with a schrader/valve stem. |
01-01-2013, 10:51 AM | #14 |
Formerly- 1972SuperCheyenne
If you buy the parts I will put it together for you at my shop. I have built several trucks and would like to help if you need it. Im up for frame off builds, engine swaps(LS included) anything mechanical. Feel free to PM me if I can help you at all.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-01-2013, 11:52 AM | #15 |
I would rather let the other person but the parts cause I don't know whats needed
01-01-2013, 02:43 PM | #16 |
I used the Air ride 4 Link, worked well. Nate built me a set of narrowed A arms and dropped 1 ton spindles , so with a stock front crossmember I can set the front cross on the ground.
67- 72 Parts collecter |
01-01-2013, 03:07 PM | #17 |
I understand, I thought you had a kit in mind. If I had my druthers, I would go with the Porterbuilt or Scotts stuff. Either way, let me know if you need an installer.
01-01-2013, 06:16 PM | #18 |
I could install it. Portebuilt makes all of it but I don't really want to change the a-arms and you have to he said. I don't really like the look of tubular
01-01-2013, 06:17 PM | #19 |
Or the rack and pinion. They don't turn sharp enough
01-01-2013, 06:21 PM | #20 |
I could have used the original arms, but I needed a little extra room for the rims I was building the truck around. In hindsight I should have just re- hooped the rims.. You could do the rear in Trailing arms and redo the crossmember to accept, I have a set of one ton trailing arms and crossmember, then all you need is bags.
01-05-2013, 03:45 AM | #21 |
hows this going?
