Old 12-31-2012, 04:44 PM   #1
Gigem
Gigem's Avatar
taller and/or wider tires on these stock rims?
Everyone is telling me to keep these because they are a classic look. I am starting to come around to the idea.
But the tires look lost in my wheel wells. Just too small for me.
What is the biggest/widest tire I can run on this rim? I think it's 15x7...
Gigem is offline   Reply With Quote
Old 12-31-2012, 04:52 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: taller and/or wider tires on these stock rims?
those are 15x6, you might could put 255/70/15 but its still going to look lost unless you add a lowering kit, stepsides are just that way
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 12-31-2012, 05:25 PM   #3
f.monroe
f.monroe's Avatar
Buy some 15x8's or 15x10's for the rear, paint them white, keep the hub caps, 275/60/15's on the rear and 235/70/15's on those stock wheels in front. Put a 2" shackle on the rear and you are set. I know where there is a pair of 15x10's for sale not far from you.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-31-2012, 07:56 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
I had 15x8's made for my Jimmy, they use stock GM OEM wheel centers and weld to new hoops at whatever backsacing you want (i had them 3.75" so they stuck out more)
http://www.trudesignwheel.net/
Im planning on doing the same for my 76 after I get a chance to start up my new engine (im in same boat as you and live in Houston too LOL)
1991 GMC Jimmy 4x4
Old 12-31-2012, 08:29 PM   #5
J Knight
J Knight's Avatar
Frank
I agree with Mr Monroe.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-31-2012, 08:50 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
still looks like way too much fendergap, 3/5 drop would be better, keep the fronts at 15x6 and go 15x10 rear imo
1991 GMC Jimmy 4x4
Old 12-31-2012, 08:51 PM   #7
Joesjunk
Joesjunk's Avatar
That may be the best looking Jimmy I have seen!! Love the colors and your wheel choice!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 12-31-2012, 09:02 PM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks!!
sorry....had to post my fav truck for example lol
1991 GMC Jimmy 4x4
Old 12-31-2012, 10:07 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Hmmm I like that look too, was looking at these
http://www.wheelvintiques.com/index....62-series.html
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-31-2012, 10:39 PM   #10
68Timber
I know the pieces fit
68Timber's Avatar
I'm a big fan of wide steelies w/stock trim. Especially with dog dish caps. Ditto what Frank said about 8's and 10's. Mine below is 10's all around, I should have gone with 8's up front.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-31-2012, 11:12 PM   #11
zirk
zirk's Avatar
Got anymore pics? I was thinking about running 10s all around, do the fronts rub?
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 12-31-2012, 11:32 PM   #12
68Timber
68Timber's Avatar
No, they don't rub. That'd be an easier problem to fix, actually, if rolling the inner fender lip might fix it. I've got Wheel Vintique 15x10's all the way around and they only come with 4.5" backspacing. That's enough to put the inner lip of the wheel too close to the lower contol arm. I'm running an 1/8" spacer up front now. The engine I have almost ready to go in is a fairly stout 383 and the spacers bother me because I know I'll flog it some - I've never run a spacer before. I'm pretty sure I could trade two of the wheels for a factory set of 15x8 rally's to a guy that wanted 8's and 10's, but I've had these powder coated and I'd have to start over on the wheel finish if I did that trade. This is the only other picture I have at the moment. 275/60-15's up front and 325/50-15's rear, 2" Ground Force springs (from Summit) up front and 2" Western Chassis shackles in back.
John
74 Honda Z50 build
Old 01-01-2013, 09:03 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
[/QUOTE]
[/QUOTE]
cool,10s in the back for sure
if stock is 6,
is 6 and 10 too much?
John
Old 01-01-2013, 12:09 PM   #14
J Knight
J Knight's Avatar
You can get those 10in rallys in a back space other than 4.5in from Wheel Vintiques and Summit.
Originally Posted by motornut View Post
[/QUOTE]
if stock is 6,
is 6 and 10 too much?[/QUOTE]Stock poverty wheels are 6in some are 6.5in. Stock rallys are 6.5in for vans, trucks are 7in for early design(73-76), 8in later design(77-87).
I got 6.5 & 10 on mine, most would say too small in the front and I would agree on a non lowered truck. 8 & 10 is realy a great all around choice IMHO if your going to run 15's.
John
Old 01-01-2013, 02:38 PM   #15
68Timber
68Timber's Avatar
Can you? I looked again, I don't see 15x10's with backspacing other than 4.5 or 5". Needs 4" to clear the front properly, or at least 4.25". Either way, they're fine on the back and look nice with 8's up front.
John
74 Honda Z50 build
Old 01-01-2013, 02:47 PM   #16
88Jimmy4x4
88Jimmy4x4's Avatar
15x10 WV rallys only available in 4.5" or 5" backspacing and 15x8 only in 4" backspacing unless you have some custom made
BTW John, I think your 6.5 and 10's is a nice setup, thats why I suggested he just get wider rears and keep the fronts with new tires all around
1991 GMC Jimmy 4x4
Old 01-01-2013, 04:44 PM   #17
carney93
carney93's Avatar
When I got my sub it had 31/10.50/15s on the back on factory aluminum 5 spoke 15x6.5s. As far as wider my uncle has 275/60/15s on the factory ford wagon wheel, 15x7 I think, on the back of his '84 Ford F150 stepside.
Money<Time+Trucks
carney93 is offline   Reply With Quote
Old 01-01-2013, 10:59 PM   #18
J Knight
J Knight's Avatar
Stock 8in rallys have a 4.25bs, as well as the 6.5in van rallys. You may have to call WV, SW, or Summit to special order anything other than 4.5 or 5in bs on the 10in wheel.
www.stocktonwheel.com
Thanks JB, but I have been considering going to 8's up front.lol
John
