Old 06-08-2003, 01:39 PM   #1
doc70sub
doc70sub's Avatar
2.5 drop w/ 275/60/15
When I drop my stock '70 Sub w/ 2.5 spindles, will the 275/60/15 on 15x8 rallys be a problem?
Thanks!
Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 06-08-2003, 08:39 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I don't think it will be a problem with the 70's. The 73-80's are a problem due to the wider front path and the design of the fender. I have 245/60R15s with 2.5 spindals and stock springs which are a problem. Anytime the frontss weighs down due to dips in the roads the tire scraps the fender. I need to replace the stock springs with new ones or stiffers ones.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-08-2003, 09:49 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Spindles require disc brakes.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-08-2003, 11:39 PM   #4
doc70sub
doc70sub's Avatar
I'll be using the '73-up 2.5" drop spindles for the 1.25" rotors as I have already rebuilt the front suspension w/ polygraphite-bushed '75 disc brake components.
Doc
Old 06-09-2003, 09:18 AM   #5
kens67chevy
when you converted your 70 to a 73 to87 front end did you put the complete steering system on the burban.
let me know
thanks ken
kens67chevy is offline   Reply With Quote
Old 06-09-2003, 09:48 AM   #6
doc70sub
doc70sub's Avatar
I used the '75 a-arms & spindles, installed new bushings & '75 spec tie rods, centerlink, etc. All I used of the existing '70 steering was the steering arm, although I've heard you just need to use the tie rod ends when doing the spindle swap.
Good luck!
Doc
Old 06-15-2003, 12:48 PM   #7
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
lowering
Just completed installation of CEE lowering kit and 2.5 spindles with 73 front lower control arms and tierods. 70 6 lug differential. with 275 /60r15 all around 15x8 front 15x10 rear. the problem i had was rubbing on the driver side rear fender wall. Tried to install wheel spacers but to no avail. I ended up cutting about 3-4 " just in case with a sawsall.One thing i would have done was install cnothes ,because now it bottoms out.By the way it is a 1970 suburban
perrosinpata@aol.com is offline   Reply With Quote
Old 06-15-2003, 03:35 PM   #8
chevymad
I just lowered my truck 2.5" front, 3" rear, yesterday.. Used springs and shocks. I have 15x10's at all 4 corners with 275/60's. No rubbing at all. Even lock to lock. Here's a pic... just to show off of course!
[IMG]http://groups.msn.com/_Secure/0UQDqAucZkkKaqWY*NJ4VHr7euz32xEESAuTuN7NltQak6yYsnhyXQkdN2ScPeb03Piklz0A7BqZzCTukvzsjDAXpy!KEnHy*wlp EZhl7TRYUJxjxApZoQcjfu8kAkbRF/lowchevy0001.jpg?dc=4675426189109759435[/IMG]
One question of my own.. The new rear coils are quite a bit lighter duty than my old ones. I will still occasionaly need to use this truck as a truck.. towing a horse trailer or hauling stuff. What company makes a rear air bag helper kit?
chevymad is offline   Reply With Quote
Old 06-15-2003, 09:37 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Pics didn't work.
Jim
Old 06-15-2003, 10:05 PM   #10
chevymad
Ya.. that seems to be an msn thing.. works on some sites not on others. Lets try it this way..
Old 06-15-2003, 10:06 PM   #11
doc70sub
doc70sub's Avatar
Offset of your 15x10s?
Looks good!!!
doc
Old 06-16-2003, 12:35 AM   #12
sbrban
I've got 275/60/15's all around on my sub and have no problems with clearance with my airride(even with the bags dumped)
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 06-16-2003, 06:19 AM   #13
doc70sub
doc70sub's Avatar
sbrban,
What size wheels are you running? Any pics?
Thanks!
doc
Old 06-17-2003, 12:35 AM   #14
chevymad
If I remember correctly they're 4" back spacing.. but they may be 4 1/2. They fit perfectly with drums but now just barely hang outside the fender with the disc conversion.
Old 06-18-2003, 01:10 AM   #15
sbrban
I'm running 15 x 8 ralleyes, There's a pic of my ride in the post "airride/swaybar" .
Old 07-14-2003, 09:12 PM   #16
dropped suburban
I replied early in the post and was curious if you plan on installing a cnotch? Well i am in the process and am having a little trouble . Brothers states that you might need to modify it. By the way it is a bolt on notch .
Old 07-14-2003, 11:58 PM   #17
72chevyLWB
Got 20's????
72chevyLWB's Avatar
15X8 ralley's have a 5" bs with the 5 lug pattern, thats why they rubbed. They are set in too far. About every 15X10 has a 4" bs which is why they fit. A 6 bolt ralley also has a 4" bs. So if you leave the ralley's you will have a little rubbing, but shouldn't be too bad. Only on tight corners I would think. I had a 3" front drop with 275/60's before with 15X8 custom wheels which had the 4" bs with no rubbing ever.
Hope this helps
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
