Finally got the cab mounts installed.. now the rad mounts...
Finally got my cab mounts installed today... went fairly smooth. Hoping for my 69 to ride smoother with the new rubber now!
But however, after I did the cab mounts my doors will barely close! I haven't did the radiator mount yet and hoping that will bring everything back to normal? Any tricks/tips on doing the radiator mounts? or do I need to pull the whole radiator out to replace them? Thanks for reading Weev-
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
Re: Finally got the cab mounts installed.. now the rad mounts...
It should be farly striaght forward just watch for cooler lines if you have those and watch the fan and shroud. Make sure the hoes have plenty of slack as well. The doors may change after the rad support bushings are done the best you can do is hope. Wha exactly kind of problems are you having on the doors not closing? are they hitting something or somewhere? a little more info would be nice .
#3 | |
The doors will techically close but VERY hard... used to be nice and easy. They are not rubbing or hitting anywhere on the body/fenders. It seems its hitting the latch before they close. Weev-
Just a heads up. I did indeed take out the radiator, fan shroud, battery/box. The mounts went it really easy and prompted me to repaint/boil out my radiator and clean it up inside there.
Also after I did the mounts under the radiator the doors close with ease again. Must really make a difference with the new rubber. Weev-
