Old 12-31-2012, 10:37 PM   #1
shipma2
what to do for a sticky window mechanisim
my drivers side window mech is stiff as a board , I have broke two cranks with the durn thing. Tips on how to loosen it up
shipma2 is offline   Reply With Quote
Old 01-01-2013, 01:01 AM   #2
J Knight
J Knight's Avatar
Re: what to do for a sticky window mechanisim
The first thing I would try is silicone lubricant on the window felt and white lithium grease on the track rollers. If it is still stiff after that, you may have something broke in the regulator or rollers.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-01-2013, 07:10 AM   #3
bk2life
replace window regulator. when its apart, lube tracks. will be like brand new again.
bk2life is offline   Reply With Quote
Old 01-01-2013, 08:26 PM   #4
swells6367
swells6367's Avatar
mine were the same I sprayed them with brake clean and re greased the tracks it was tricky I had to use a coat hanger wire to get the grease in the tracks but they work better now.
Scott wells
1973 k10 81 7.2l power-train
swells6367 is offline   Reply With Quote
Old 01-02-2013, 02:34 AM   #5
shipma2
il give that a try thanks guys
Old 01-02-2013, 08:59 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
any parts been changed?
check regulator/track alignment in the door
lube for sure
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-04-2013, 02:02 AM   #7
shipma2
nope its a stock roller assembly il tear into it tommorow or sunday .
Old 01-04-2013, 08:23 PM   #8
bnoon
I just had to realign my driver's side front track due to the cold snap we had the last few weeks. Made everything bind up harder than usual and popped the front edge right out of the track. Once I loosened the track and popped it back in, I gave the felts some silicone and the rollers some white lithium grease and it's better than it's ever been since I've owned it. Took maybe 20 minutes total for the one side. Passenger's side is next tomorrow morning.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-05-2013, 10:14 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
seen them so bad the window dosn't roll to the top
wondered if it had been replaced,or maybe worked on
John
Old 01-07-2013, 11:10 AM   #10
bnoon
Yeah after I first put it back together before I lubed everything it wouldn't go all the way up because everything was so gummed up. I had to pull the glass up as the button was pushed, then I could at least drive to the parts store to get the white lithium without freezing my arse off LOL! When I did the passenger side this weekend, I found that the motor mechanism mounting bolts were way loose, which is why my window kinda "dropped" the first couple of inches when putting it down each time. I also lubed up my locks while I was in there and now the key locks/unlocks the doors so much easier and the power locks work much quicker as well and don't require a few pops of the switch to lock in the cold. The bad part for me was the driver's side outer felt strip was so brittle that it broke about a 4 inch piece off when I was working on stuff. At least those look easy to replace.
window repair
