C10 CLUB Y QUE!
accuair
i want to purchase accurair but not sure what i need.
i have a regular air suspension setup tank compressor airlines valves what do i need from accuair to make my current set up complete. |
C/10 junkie
Re: accurair
Just some $$$
![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Re: accurair
If you want the elevel with the ride height sensors you can buy it for about 1500 and use your tank and compressors.
C10 CLUB Y QUE!
Re: accurair
lol i got the money just trying not to spend it all...
#5 | |
C10 CLUB Y QUE!
Re: accurair
this one right? but can i still use my valves? |
C/10 junkie
Re: accurair
Man if you could get the e-level system that would elimate any ride height worries. 1 2 3 and your at the exact level stance you program in. That's gonna be my goal when I get there.
Re: accurair
I'm not sure if you can use your valves or have to use theirs.I would email Accuair and ask about that before buying it.
Re: accurair
Just keep in mind that the Accuair valve block is 500$ by itself!
'71 GMC pickup; "Ashley," ![]() |
C10 CLUB Y QUE!
Re: accurair
Thats the reason why I'm trying to avoid it out I can
Posted via Mobile Device |
Re: accurair
Yep, in the Accuair install manuals (available free on their website) it explains the wiring harness for if you use other electric valves, and all you would need is the kit above.
Re: accurair
You can use the E-level with ODE valves, but if other valves besides the VU4, it would wear the solenoid over time. This is because the e-lvel will pulsate the valve to adjust to the right heigh accurately. By the time you buy all the fittings and the valves, you are about $100 or so away from the price of the VU4. The VU4 is a nice, clean setup and plug and play to the e-level. I suggest this route if in the budget.
- Travis http://www.azproperformance.com/Accu...ELS4-TPAD.html |
Re: accurair
Yeah the VU4 is definately awesome! Mount it, plug in 5 airlines and a harness, and you're done!
#13 |
needs more $$$
Re: accurair
If you haven't started the plumbing yet, I would definitely consider going with the entire accuair block and e-level system and selling the valves you currently have. Considering the time and headaches it took to plumb and track down leaks in my 8 valve set up, I don't think I'd do anything else the next time around.
1970 2wd Blazer |
#14 |
C10 CLUB Y QUE!
Re: accurair
I may consider buying pieces of it as I go.
#15 |
Re: accurair
If your already using the valves i would keep them and add the e level.Once you wear the valves out replace them with the manifold.Or if they are a good name valve rebuild them and sell them to get a little bit back.
#16 | |
C10 CLUB Y QUE!
Re: accurair
#17 |
Re: accuair
i replaced a good working 8 valves set up with the e-level
and its worth every penny , thet are quieter in both up and down less leaks and just over all size is amazing Posted via Mobile Device
///Relaxed Atmosphere |
#18 |
C10 CLUB Y QUE!
Re: accuair
i guess the right choice would be to get everything new.
but i want to use the money on other projects so im just going to start buy buying. just the speed switch controller and go from there. Ive been running my setup since 2006 with no problems ill just slowly wait and maybe i get a great deal down the road |
#19 |
Re: accuair
Hit up some of our vendors see what kinda discount you can get.
