Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-31-2012, 11:57 PM   #1
fatgump
fatgump's Avatar
test run
Did a test run. First time I got her to 5000 rpm. The speedometer is not calibrated yet. The specs are 355cu, 10:1 compression, 4:10 gears and 29" tall tires. I have a major exhaust leak, that melted my valve cover gasket, tried to modify my headers to accommodate angle plug heads. It is amazing how fast a plug wire will burn when it touches 1000 degree headers. Custom headers on the way.
http://youtu.be/N1Amz5J4v4A
fatgump is offline   Reply With Quote
Old 01-01-2013, 10:49 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: test run
PM sent
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
