Old 01-01-2013, 12:20 AM   #1
MattBMiller
MattBMiller's Avatar
No heat at idle in my 71 5500
Just picked up a 71 5500. Went out and started it up today to move it to plow snow. Let it run for a bit in the driveway while i got the tractor out. The blower motor will not blow at idle. Scraped the windows and took it for a spin and I had hot heat blowing once I got moving. Pulled up to a light and the heat/defroster stopped. Any ideas? Probably.going.to have to make room in the garage tomorrow and see what I can find.
MattBMiller is offline   Reply With Quote
Old 01-01-2013, 12:45 AM   #2
Mister-B
Re: No heat at idle in my 71 5500
I bet it needs a new blower motor. You can get one at autozone for like $21. Will take you about an hour to change. Check my previous posts for additional info
Mister-B is offline   Reply With Quote
Old 01-01-2013, 12:57 AM   #3
ole dollor
ole dollor's Avatar
are you saying the blower motor does not work, or the heater wont get hot unless you are moving. if it does not get hot unless you are moving, then check to see if you are low on water, if the blower motor only works while moving than you have an problem with the wiring, or a switch....can you give more info.
ole dollor is offline   Reply With Quote
Old 01-01-2013, 01:01 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Does it blow but just cold air or not blow at all? If the blower is blowing cold air then it may be low on coolant. It is normal when the coolant is low for the air to blow cold at idle and to get hotter with engine rpm. If the blower does not blow at all, that would be a different issue.
Also, you might have a bad blower motor resistor which will stop the blower from blowing on high. It will blow on low and medium but not high.
Curious to see what is going on with it.
TBONE1964 is offline   Reply With Quote
Old 01-01-2013, 01:16 AM   #5
Mister-B
I could be wrong, but I recently replaced my heater control unit, and so I got a good close up look at the inner workings. It almost looks like the blower motor doesn't come on until the switch is past about the half way point
Old 01-01-2013, 02:11 PM   #6
MattBMiller
The blower does now blow until I get moving, no airflow from the vents when im stopped.
Old 01-02-2013, 01:07 AM   #7
ole dollor
ole dollor's Avatar
i would run a wire from the battery or a known 12 volt source like a fuse thats hot, and hook the wire to the blower motor and see if it blows on high . if it does you have a bad switch or wiring problem.
