Old 01-01-2013, 12:22 AM   #1
bowtieboy1993
SBC Headers
Hello everybody, I have a 1962 short wide with a swapped front k-member out of a 78 c10, and a mildly built 355. I have a set of long tube headers for 73-87 trucks. But they do not fit very well and was wondering what everyone else was using. I had heard longtubes off 1st gen camaros worked. Thanks for any input.
Sam
bowtieboy1993 is offline   Reply With Quote
Old 01-01-2013, 01:12 AM   #2
bowtieboy1993
Re: SBC Headers
anything i should be looking at in particular?
Old 01-01-2013, 02:28 AM   #3
Captainfab
60-66 Nut
Re: SBC Headers
The Hedman #69260's are the headers designed to fit these trucks. If you are still running a manual trans, you have to be careful using car headers as they will typically hit the bellhousing crossmember.
Old 01-14-2013, 12:20 AM   #4
bowtieboy1993
Re: SBC Headers
Those were actually the first set of headers i tried, and they didnt even come close to fitting, because of the late-model front crossmember, and now iv got a set for 73-87 that still have some minor clearence issues
Old 01-14-2013, 02:00 AM   #5
Captainfab
60-66 Nut
Re: SBC Headers
It sounds like maybe you have moved the engine forward from the original location? The '73-'87 suspension crossmember isn't any bigger than an original '63-'66 crossmember. Either one of those headers will fit a '60-'66 with the engine in the original location.
Old 01-14-2013, 03:39 AM   #6
61 chevy
61 chevy's Avatar
Re: SBC Headers
I put in shorty headers for a81 camaro. They fit perfect. I have a 61 chevy. sb 400 auto. And i swaped the front end out for an 80 chevy. Got them off amazon for $150 ceramic coated.
61 chevy is offline   Reply With Quote
Old 01-14-2013, 04:59 AM   #7
Vernski
Re: SBC Headers
One point that some discover if they are going to bag or slam their trucks is the long tube headers making contact with the ground beware...Vernski
Vernski is offline   Reply With Quote
Old 01-14-2013, 12:49 PM   #8
jimmy1614
Re: SBC Headers
Captain pointed me in the direction of Hedman 68600. They fit great except for a very slight clearance to the drivers side engine mount. They don't hang below the frame rails either so they will work if your going really low. 66 c10 swb with 89 suburban crossmember, sbc 350 and 700r4.
jimmy1614 is offline   Reply With Quote
Old 01-14-2013, 02:29 PM   #9
LVPhotos
LVPhotos's Avatar
Re: SBC Headers
I run the shorties.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-14-2013, 03:12 PM   #10
64C10Fleet
64C10Fleet's Avatar
Re: SBC Headers
I did quite a bit of research when it came to headers for my '64; I, too, have a mildly built 355. I found a study that showed long tube headers compared to the Dorman 2.5" outlet Rams Horn style manifolds and the results were pretty close. If you're looking for good performance and something that isn't going to turn your cab into an oven, I would consider the Rams Horn. You can get a set at Speedway for about $115. Here's a link:
http://www.speedwaymotors.com/Dorman...air,58966.html
They also make the manifold with a 45 degree kickback if you don't have a straight shot. I'm not sure what the clearance is like on your truck with that crossmember, but all I had to do on mine (with stock crossmember) was move the engine mounts to the rear mounting position.
If you do decide to go with the Rams Horn style, let me know and I'll get you a part number for the downpipe and donuts. I just picked up the downpipes and donuts this past weekend.
64C10Fleet is offline   Reply With Quote
Old 01-14-2013, 05:51 PM   #11
JR Dean
Re: SBC Headers
Please post the part numbers for the down pipes and donuts. I have the same situation with a '63 GMC with a 355SBC. The rams horn manifolds that I have are 2 1/2" outlets and straight down. They appear to be the same that I had on a '62 Impala with a 300 horse 327. By the way the bell housing crossmember has been removed from my GMC.
JR Dean is offline   Reply With Quote
Old 01-14-2013, 06:13 PM   #12
PoDuck
Re: SBC Headers
What is the difference between those rams horn manifolds and the stock ones for the 283?
PoDuck is offline   Reply With Quote
Old 01-14-2013, 06:28 PM   #13
oldtrux
oldtrux's Avatar
Re: SBC Headers
stock 283 ramhorns are 2'' outlet
oldtrux is offline   Reply With Quote
Old 01-14-2013, 06:54 PM   #14
PoDuck
Re: SBC Headers
That makes sense.
Old 01-14-2013, 08:44 PM   #15
64C10Fleet
64C10Fleet's Avatar
Re: SBC Headers
Here you go JR, let me know if you want to see a pic and I'll try to snap one tomorrow afternoon.
Downpipe is a Jones AWHC212, link to it on Summit...
http://www.summitracing.com/parts/jex-awhc212
Donut gasket is a Walker 31391, link to it on Summit...
http://www.summitracing.com/parts/wl...FQ0GnQodQhUA8g
You can find both at any local reputable auto parts store, I just found a link to Summit for both when I Googled.
I was told these Dorman Rams Horn manifolds were originally designed for use on circle track cars. I do know some cars are only allowed to use parts that appear to be stock, so I guess there could be some truth to it.
Old 01-14-2013, 10:15 PM   #16
JR Dean
Re: SBC Headers
Thanks 64C10Fleet! That looks just like what I need. These manifolds are machined to take a special formed donut gasket. I hope that the Jones pipe flange is made the same way. I've had that type of gasket made of a composition material and also of soft steel. There is a circle track just a few miles away and I've heard that some of those guys use these Corvette type manifolds. So it looks like it will soon be time to build another exhaust system. I probably don't need a photograph but maybe it would help someone else.
Old 01-15-2013, 02:42 PM   #17
64C10Fleet
64C10Fleet's Avatar
Re: SBC Headers
Yeah, couldn't find a downpipe in 2.5" that would fit the donut supplied with the manifolds. The pipe I posted is flat, and the donut I posted is flat on one side and beveled on the other.
Old 01-15-2013, 03:08 PM   #18
JR Dean
Re: SBC Headers
64C10Fleet, That setup should work OK using the downpipe and donut that you posted. The manifolds that I have both have a narrow machined flat ring near the edge but not wide enough to provide a good gasket seal.
Old 02-02-2013, 07:45 PM   #19
bowtieboy1993
Re: SBC Headers
Update! Just got home from a local swapmeet where i scored a set of Hedman longtubes designed for 67-91 C10,s Part number 69088. Mocked them up to my engine and they fit like a glove! I am still going to make a little notch in my frame for the number 3 tube on each side as there is only about an 1/8" of clearance but other than that I will not have to do anything else!
Thanks for all the help,
Sam
