Old 01-01-2013, 12:31 AM   #1
greatdane
greatdane's Avatar
electric choke dash light
Put a new edlebrock 1406 carb on my 84 tonight. The po had disconected the electric choke wire on the old carb(also a edelbrock). When I connected it the choke light came on in the dash. Truck started fine came off high idle fine but the light stayed on in the dash? How does that light work on the factory carb??? Does it come on when you turn the key then go off after you start the truck? Or does it stay on until the choke goes off? When "should" it go off? I have not adjusted the choke any yet.....
Good news is the truck runs alot cleaner now. No more raw gas smell...
1993 Silverado C2500 Single Cab LWB
2007 Chevy Silverado 1500 Crew Cab LTZ 4x4
1974 AMC Matador Coupe - The Mat
greatdane is offline   Reply With Quote
Old 01-01-2013, 09:31 AM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Re: electric choke dash light
Take a look here:
http://67-72chevytrucks.com/vboard/s...ighlight=choke
My bet is that your oil pressure switch is disconnected. The connector to the oil pressure switch on my 84 K10 is jumpered to get rid of the light and power the choke heater.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 01-01-2013, 10:16 AM   #3
Wrecked1982
Wrecked1982's Avatar
wow ive never seen that kinda light in my truck
Wrecked1982 is offline   Reply With Quote
Old 01-01-2013, 02:13 PM   #4
greatdane
greatdane's Avatar
leaning twards just leaving the electic choke wire off. Truck starts and runs fine without it.
Old 01-02-2013, 04:44 PM   #5
tucsonjwt
If your truck starts fine and idles OK without the choke hooked up, then you are very lucky. I would say leave it alone until you can't start it or you get dieseling when you shut it off, or it runs rich. If you have trouble with your stock choke I recommend converting to a manual choke - I did that with all old vehicles I have owned, including 3 squares.
tucsonjwt is offline   Reply With Quote
Old 01-03-2013, 01:18 PM   #6
greatdane
greatdane's Avatar
Found out that the factory choke wire does NOT provide a full 12V when key is on.
I'm going to run a new wire to a "keyed" 12V source and see how she works.
