Old 01-01-2013, 02:01 AM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Wiring diagram for headlight switch?
I'm going a custom gauge cluster and I'm not going to use the factory headlight switch. I need to know what wires control the marker/cruising lights and the headlights. I'm just going to run them off a toggle switch on a panel. I see the switch has a plug with numbered male ends on the switch. Can someone tell me what is what? Thanks!
prostreetC-10 is offline   Reply With Quote
Old 01-01-2013, 02:09 AM   #2
Mister-B
Re: Wiring diagram for headlight switch?
Try this http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Mister-B is offline   Reply With Quote
Old 01-01-2013, 02:20 AM   #3
prostreetC-10
My Carbon Footprint
I'm assuming the GMCs and Chevys are the same? Thanks for the link!
Old 01-01-2013, 06:04 AM   #4
SS Tim
SS Tim's Avatar
Also need to consider that the factory headlamp circuit breaker is part of the switch. So if you remove the switch there will be no circuit protection. Even if you are going to add headlamp relays you should plan on a fuse or circuit breaker on the control side.
SS Tim is offline   Reply With Quote
Old 01-01-2013, 10:38 AM   #5
Mister-B
No problem, man. Chances are, GMC is the same as Chevy, but one of the few differences IS that the GMC has an extra set of headlights, so I don't know for sure. This should get you very close though. That, and following Tim's advice
Old 01-01-2013, 11:07 AM   #6
prostreetC-10
My Carbon Footprint
Great points from both of you. I do realize about the fused part and that will be addressed. Thanks again.
Old 01-01-2013, 02:02 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Here's a GMC v8 schematic for engine compartment in case you need it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
