Old 01-01-2013, 04:25 AM   #1
Trsmotrhed
Trsmotrhed's Avatar
Removing in cab tank?
What have you guys done with the brackets that held the tank down? Kinda ugly, even behind the seat. Was thinking about cutting back to the bolts and welding a piece to cover the gaps. I'll post pics when done unless someone had a better idea. Thanks.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 01-01-2013, 09:08 AM   #2
bonehead
bonehead's Avatar
Re: Removing in cab tank?
Really none of my business, but why remove the cab tank?
I am in the process of putting mine back into the cab. Seems like a lot of work for little gain to remove it.
Good luck either way.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 01-01-2013, 09:31 AM   #3
Hx16457
Hx16457's Avatar
I am using mine! They are holding down my tank!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 01-01-2013, 10:37 AM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
I've seen where guys have used them as a shelf bracket,side to side and boxed across the front..cover it with the same carpet as is on the floor,cleans it up nicely.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 01-01-2013, 12:35 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Here's what I did with mine. I just sliced off the front portion and the vinyl full floor mat covers up what's left:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-01-2013, 12:50 PM   #6
Trsmotrhed
Trsmotrhed's Avatar
Markeb01, that's what I had on mind to do. Thanks for the pics.
The reason I'm removing the tank is they smell on a hot day, not as much capacity as a frame mounted tank and safer. I'm also putting a fuel injected engine in and want to install a fuel pump inside the tank, not external. To noisy, been there done that. I have to redo my whole fuel system anyway.
Thanks for your thoughts on this.
63 SWB C10
Old 01-01-2013, 12:59 PM   #7
Trsmotrhed
Trsmotrhed's Avatar
That did make me laugh, even with a hang over, that's what they're suppose to be used for.
63 SWB C10
Old 01-01-2013, 01:26 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Me too!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
