will headers for a K10 fit a C10?
I was given a set of headman hedders for a K10..part number 69230. they have a little better clearance for my angle plugs..anyone ever use K10 headers on a C10?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
I think that they will tuck up in the frame rails un like the 2wd headders that sit below the frame rails. They should fit. I think....
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Formerly yellow72custom
I'm pretty sure heddman truck headers fit any chevy P/U, 2wd or 4wd, as long as its SBC powered from 67-87. Might want to check your Jeg's catalog to make sure.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
ttt
I installed a set of headers from a C20 on a K20 so they most likely will work. They were a brand called JR whatever that is....
Depends on the header, but most likely they will not. Unless you have the 2 wheel drive V8 mounted in the 6 cylinder postion. But it really does depend on the header. A GOOD header, meaning one that was designed for a 67-72 whether automatic or manual that fits without modifying the OEM clutch linkage most likely will NOT fit, but a header that fits the 73 and up K series probably will.
CCRider
You should have no problems with an automatic...if it is a stick you may run into interference with the z-bar
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
headers
I used 2wd Dynomax headers on my K20 and just used the threaded rod from the Z-bar to clutch fork from a 2wd and bent it around the header tube. 20,000 miles and no problems.
1972 K/20 355 c.i.d. sleeper "Circus Wagon" |
