01-01-2013, 11:53 AM | #1 |
hei in a 250 six
Ive searched and cannot find any info for installing an hei distributor in my 250 six.Ive seen numerous pics with them on one but no info.Anyone have the details?I dont really care for the looks of them and Im familiar with the pertronic units but ive retrofit them on v8s in the past with good results,the hei that is.thanks ron
01-01-2013, 12:01 PM | #2 |
Re: hei in a 250 six
I just pulled one out of a newer 6 banger.....at pick and pull
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-01-2013, 12:35 PM | #3 |
Any 250 or 292 HEI will work, they make a built in coil ( on top of the cap like a V8 ) and a seperate coil that is usually bolted to the side covers. Just drop it in and run a 12 volt wire from the fuse box that comes on with the key and you are good to go.
I have done countless of these change overs. You can get the HEI out of cars or trucks, novas had 6 cylinders alot.
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
01-01-2013, 02:28 PM | #4 |
That shows how much i know about 6 bangers,I thought the v6s and v8s dominated the years of the hei,never knew the straight 6s had them.thank for the info ron
01-01-2013, 04:21 PM | #5 |
you can also run a pertronix kit way easy to istall
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-02-2013, 07:23 PM | #6 |
petronixs is very easy to install, after i installed mine i just had to adjust the timing slightly. Comes with instructions
