01-01-2013, 02:36 PM | #1 |
Where to buy this Carrier bearing
Can anyone please help. I am looking for this bearing.
http://67-72chevytrucks.com/vboard/s...d.php?t=334870 Thanks Posted via Mobile Device |
01-01-2013, 03:15 PM | #2 |
Re: Where to buy this Carrier bearing
Not sure, but I'm signing on for the info
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
01-01-2013, 06:35 PM | #3 |
Junior Member
Check out Rock Auto's website, they may carry them. I have got quite a few parts from them over the years for these trucks.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
01-01-2013, 06:46 PM | #4 |
Updated the original thread with contact info for Driveshaft King
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-01-2013, 06:52 PM | #5 |
Ok so I found the bearing. Te problem now is the rubber donut. I attached a few pictures after I took it apart. I forgot to take them before I disassembled them. I will try and update from here on out.
Posted via Mobile Device Ok so I have to reduce the images and then I can try an load again |
01-01-2013, 06:53 PM | #6 |
might find what you're looking for here. Not sure your year truck... this clip for a 68 (since the link you posted was for a 68).
Am assuming you could stroll into Napa or Oreilly or CarQuest and find what you need. Carrier bearing is a pretty common consumable item on these trucks. Replaced more than I've wanted to replace... http://www.oreillyauto.com/site/c/se...make=Chevrolet or here http://www.napaonline.com/Catalog/Re...&Ntt=&N=599001 101968 50014 2014024 28240 http://www.rockauto.com/catalog/raframecatalog.php (will have to work down to your specific vehicle via make/yr/model/drivetrain/driveshaft/center bearing support or something like that.. |
01-02-2013, 02:36 PM | #7 |
the boat guy
Carrier bearings aren't any more a consumable item than ujoints.
Any time you replace a carrier bearing you SHOULD have the shaft checked for ballance. Being out of ballance will kill a carrier bearing quick, not so much the bearing but the rubber surround for the horseshoe style and the brackets for the car style carrier. Any time I've ever replaced a carrier bearing..... a few hundred times. The shaft needed some weight to make the ballance perfect. That's with a shaft that is straight and unmolested. If you start changing ujoints and flipping yokes around or bend the stub or shaft (has the truck ever ran over anything in the road?) You will have a ballance issue. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-02-2013, 11:53 AM | #8 |
I want to let everyone know that I sent the driveline to Boyd's drive line service in Stockton. Barry completely went through it replacing the Bearing, installed the bearing housing and u joints and completed it by balancing it. Great guy if you need to have driveline work done call him. I Finally got the truck on the road and wow what a difference.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
02-02-2013, 02:09 PM | #9 |
Ive had the best luck finding parts at NAPA.
02-04-2013, 01:40 AM | #10 |
Quick60 even napa couldn't get the parts to fit this style.
