Old 01-01-2013, 03:35 PM   #1
David Pearcy
lowering a 67 3/4 ton
I have a 67 3/4 ton GMC with a dana 60 rear end and leaf springs. I want to lower the rear end 4 inches. What are the options to do this?
David Pearcy is offline   Reply With Quote
Old 01-01-2013, 05:41 PM   #2
erikh09
Re: lowering a 67 3/4 ton
I have the same truck. I did swap the rear to a 5 lug but I just removed leafs until I reached the height I was looking for. Mine is a camper cruiser so I am not sure if I have more leafs than your truck but I think I removed 5 leafs.
erikh09 is offline   Reply With Quote
Old 01-01-2013, 08:21 PM   #3
terry b
terry b's Avatar
If you are going to haul things in it i dont think i would remove five leafs without putting air bags under it also. I have a c20 with leafs and want to lower mine also about two inches and improve the ride some. Let us all know what you do and how it turned out. terry
terry b is offline   Reply With Quote
Old 01-01-2013, 10:07 PM   #4
Belairboy55
Active Member
GMC PAUL'S SELLS LOWERING SHACKLES AND SPRINGS FOR C 20 trucks. You could achieve 2" with shackles. Installing a flip kit would lower the truck and keep load range up.
Belairboy55 is offline   Reply With Quote
Old 01-02-2013, 10:44 AM   #5
David Pearcy
Mine is a Camper Cruiser too. The flip kit sounds like a good way to go. How much will that lower it? Will I need to C-notch the frame?
Old 01-02-2013, 03:35 PM   #6
terry b
terry b's Avatar
I think that will drop it like four or five inchs with a flip. Yes you need to notch it.
Old 01-02-2013, 03:40 PM   #7
terry b
terry b's Avatar
Thanks 55. Going to check them out. terry. Hey david how far are you from jackson? I would give you a hand if you need it.
lower dana 60, lowering my truck
