01-01-2013, 04:49 PM | #1 |
Blown fuse?
I start the vehicle, everything works fine then all of a sudden my dash lights go off along with my tail/brake and side marker lights.. The headlights still worked (thank god!)
This happened at 3am after I closed the bar I manage down on NYE with cops thick as flies out and about but luckily I still managed to shuttle my drunken buddies home in the C-Dub without getting hassled Just a blown fuse? Like I said, the only light that seems to be working is my headlights, and high beems. The high beem light is the only dash light that is working
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up! http://67-72chevytrucks.com/vboard/s...d.php?t=545486 Gentlemen wear a bow tie. |
01-02-2013, 03:24 PM | #2 |
Re: Blown fuse?
Replaced fuse, fuse blew again. Only seems to happy if I mess with my heater controls? Also only started with the snow and wetness I have had in my area.. Possible short?
01-02-2013, 03:52 PM | #3 |
Re: Blown fuse?
There is a bulb and wire in the heater control Check an see if it is pinched or frayed May be shorting when you move heater levers Should be a single grey wire
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
01-02-2013, 04:38 PM | #4 |
20' Daredevil (Ret)
Re: Blown fuse?
Short to ground, yes. Try replacing the fuse with a test lamp, then move the heater controls around (or anything else that might affect it). If the test light comes on bright, that's when the fuse would blow. Dim or no test light = no short.
