01-01-2013, 05:05 PM | #1 |
Boyd tank install
I need some help, i cant seem to get my head wrapped around what is needed to install my Boyd tank.
it will be going in my 70. I bought the carburated tank, product number 14001. Bed fill 2" (center). I will be using an Attwood 2" deck fill. P/N 66411-1. This is the only 2" filler I could find. 1/2" NPT Vent. I plan to use a motorcyle vent. 3/8" NPT Return. I plan to plug. 3/8" NPT draw. What is this? Is this were the fuel line to the pump connects? It will come with the sending unit. This is where the tan wire for the guage and the ground will contect.
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
01-01-2013, 09:49 PM | #2 |
Re: Boyd tank install
i cant help, but id like to know also. i thought the tank comes with all hardware ready to install minus the gas cap
01-02-2013, 12:17 AM | #3 | |
Do you have the bed on your truck? When I mounted mine my bed was off of the truck, made it easy to install. With the bed on the truck it will be a challenge to install. |
01-02-2013, 12:25 PM | #4 |
Yes the bed is on and I do not plan on removing. Don't worry, everything i do is a challenge. Is the draw on the bottom of the tank or does the draw come out of the sending unit?
01-03-2013, 08:51 PM | #5 |
Are there ay Boyd tank users out there?
01-03-2013, 08:54 PM | #6 |
86 Scottsdale
Haven't installed a tank back there, but I had my bed off in about 20 minutes last time I tried by myself. I'd lift it out of the way, and do everything the easy way, then drop it back on.
01-04-2013, 12:31 AM | #7 |
01-04-2013, 12:32 AM | #8 |
02-23-2013, 07:50 AM | #9 |
any finished pics?
02-23-2013, 10:08 AM | #10 |
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
02-23-2013, 02:50 PM | #11 |
I have a Boyd's tank yet to install
02-23-2013, 04:05 PM | #12 |
I also purchased and installed a tank from Boyds. I got a new sending unit and a rollover vent from him also. I ran 3/8 stainless tubing from the tank to the fuel pump. Try to get some pics when I get home..
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-23-2013, 04:09 PM | #13 |
I have one also, yet to install. I'm running a LS motor, so I need to run an external pump. As I bought the regular tank also.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
02-23-2013, 05:11 PM | #14 |
I would like to see what some of you used for filler cover, installed in the bed of the truck.
Posted via Mobile Device |
02-23-2013, 07:51 PM | #15 | |
I bought the Stealth EFI version of their tank but I had them instal a block off plate incase I decided not to go with EFI. |
02-25-2013, 01:57 AM | #16 |
Subd. I'm sure someone will chime in soon
02-26-2013, 01:11 PM | #17 |
I got this door for my bed fill non-efi tank. I haven't put it in yet, but it seems really nice.
http://www.streetrodhq.com/search.la...artment+Search
