Old 01-01-2013, 05:42 PM   #1
Southern Shaker
Thumbs down Will this Fit on my truck?
i have a 98' chevy suburban thats a parts truck in my collection of junk cars with a power steering set up will the power steering pump and parts fit on my 70' ? i Was also thinkin of taking the whole front suspension set up (since its a 5 lug) and swapping it for my front drums ? will these parts work
Southern Shaker is offline   Reply With Quote
Old 01-01-2013, 06:20 PM   #2
Re: Will this Fit on my truck?
I don't think the 88-98 models swap over like the 73-87 era trucks did.
Hopefully someone more knowledgeable than me can advise you.
Old 01-01-2013, 06:27 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Will this Fit on my truck?
That depends on how you mean fit! Lol.. No welding grinding drilling new holes then I would say no it want fit.
If you don't mind modifing the frame some with new holes for mounting then it should work.
Will it be a bolt in No.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-02-2013, 11:30 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
The 88 and later trucks don't have a bolt in front crossmember. It's welded in. You need to find a pre 87 donor.
WIDESIDE72 is offline   Reply With Quote
Old 01-03-2013, 08:30 AM   #5
hugger6933
The steering box won't work either as it mounts on the inside of the frame instead of the outside. The pump however will work you will either need to use a hose adaptor or remove the power steering pressure regulator from the pump and change it with one from an older pump.
hugger6933 is offline   Reply With Quote
