Old 01-01-2013, 06:42 PM   #1
Northbound
Tires on a 4x4
I'm replacing the tires on my '89 K2500 hd silverado. It currently has 245 75 r16, and I'm thinking of going to 285 75 r16 or 33x12.5x16. Anybody done this without a lift ... any issues?
Northbound is offline   Reply With Quote
Old 01-01-2013, 07:08 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Tires on a 4x4
Yes. I did 285 75 16 on my 97 and 98 k1500 and currently on my 99k2500. The only issue you will have if any is the tire hitting the valance. Are are you using factory wheels
95 S_Trucker is offline   Reply With Quote
Old 01-01-2013, 07:28 PM   #3
Northbound
Re: Tires on a 4x4
Yes the OEM steelies ... the valance ... that ruberrized skirt over the upper contol arm?
Old 01-01-2013, 07:29 PM   #4
Northbound
Re: Tires on a 4x4
Do you have a lift?
Old 01-01-2013, 07:36 PM   #5
wwj75c30
wwj75c30's Avatar
Re: Tires on a 4x4
my dads 97 k1500 has 285/75/16s which come out to 33x11.50x16 no lift stock wheels it'll only rub lock to lock when flexing other then that they fit good
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 01-01-2013, 09:54 PM   #6
benoit454
Chris
benoit454's Avatar
Re: Tires on a 4x4
no valance is the plastic thing that's mounted under the bumper IF it's still there.
I run 285's on mine NO lift, and it's 1/2 ton 3/4 tons sit higher usually.
if you put them on and they rub crank up your torsion bars some. I know a guy who has a 2500 I think it is and runs 315/75-16's and it's aftermarket wheels. He had no lift only cranked his bars up some.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-02-2013, 09:02 AM   #7
Northbound
Re: Tires on a 4x4
Thanks Guys ... 285s are it then.
Old 01-03-2013, 11:12 AM   #8
Re: Tires on a 4x4
I just remove that valance piece. Mine re 3500s with torsion bars cranked. The one w/utility bed had 8" wheels. 315/75s would never work on these trucks. My 285s will very rub,rarely:
Old 01-04-2013, 06:36 AM   #9
benoit454
Chris
benoit454's Avatar
Re: Tires on a 4x4
315's or 35's do work on these trucks seen it done over and over, 1500's 2500's even 3500's....
http://www.gmt400.com/forum/showthre...=badazzbulldog
I've seen 36's and 37's on some too, but I'm almost positive they fully cranked AND had to trim.
Chris
GIT R DONE!!!!!!
Old 01-06-2013, 09:26 AM   #10
Northbound
Re: Tires on a 4x4
My truck has no valance, don't think it ever did, but maybe the PO had taken it off. I've had two '89s, and neither had a valance, I know my old beater never had one as I got it of a 3 yr lease and it didn't have one when I got it with less than 40k on it.
In any case, a little rub will be ok as I don't really use this (newer to me) truck foe severe duty or off roading. I like the look of the bigger tires, and being an HD, it has a Turbo 400 with no overdrive and fairly low gearing in the rear axle (Dana 60 I think). It would also be nice to have the bigger tires for the rare occasion where I do need to go on bush roads.
Tks
Old 01-07-2013, 09:17 AM   #11
tripleD
tripleD's Avatar
Re: Tires on a 4x4
33x12.50x15s and no lift
triple d
tripleD is offline   Reply With Quote
