Lock barrell removal..How to?
What is the secret to removing the ignition key lock barrell. I know you use a paperclip but what else am I missing? Is there a certain method or technique you use?
![]() Join Date: May 2012
Re: Lock barrell removal..How to?
With the key in, turn all the way left. Push in paper clip and key with cylinder at the same time. May have to wiggle a little.should come right out.
John Posted via Mobile Device |
Sorry , should have said push in clip and pull key and cylinder out at same time.
heres a older post on removal that i posted some pictures in:
http://67-72chevytrucks.com/vboard/s...d.php?t=532014
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
Got it!, thanks...
