Old 01-01-2013, 09:31 PM   #1
1987cut
1987cut's Avatar
ECE engine mounts and trans problems
hey guys, I ran into a snag yesterday. I have a 99 ls1 out of a camaro and ece mounts going into my 72 c10. I had to remove some material on the engine cradle. no big deal, but my trans seems to be too low at the tailshaft. I also have a ece trans mount. it just seems like it needs to come up some. has anyone else ran into this?
1987cut is offline   Reply With Quote
Old 01-01-2013, 10:16 PM   #2
Nohatch
Re: ECE engine mounts and trans problems
What trans do you have?
Nohatch is offline   Reply With Quote
Old 01-01-2013, 10:38 PM   #3
1987cut
1987cut's Avatar
oh sorry, that would help wouldn't it? 4l60e out of the camaro
Old 01-02-2013, 07:23 AM   #4
joesgreen67
joesgreen67's Avatar
I an using the same setup in my 67. I put a .50" thick spacer under the trans mount to bring it up a little. Anything thicker and the trans would touch the lip on the cab (bellhousing area)
joesgreen67 is offline   Reply With Quote
Old 01-03-2013, 12:04 PM   #5
1987cut
1987cut's Avatar
Thank you joe, i have to get me a angle finder and then I'm gonna try your suggestion. I'm gonna see if I can get about 4 degrees negative out of it.
