Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-01-2013, 10:56 PM   #1
JQ-72
JQ-72's Avatar
Need 60-62 frame horns - HELP!!
I've started doing some work on my 1960 GMC and hope to have it on the road pretty soon. If someone has a donor frame to sacrifice, I'm needing both front frame "horns". If someone can help me out, I'd like to have them cut just in front of the radiator support mounts, to give me plenty of room to work with. Thanks!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 01-01-2013, 11:51 PM   #2
travz500
travz500's Avatar
Re: Need 60-62 frame horns - HELP!!
i can help you out pm me how long you want the pieces cut I got a 66 frame that should be the same
travz500 is offline   Reply With Quote
Old 01-02-2013, 12:29 AM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Hey Travis,
The 60-62 Frames are different than the 63-66.
The horns are also different.
66 C20 Service Truck:
Old 01-02-2013, 12:54 AM   #4
travz500
travz500's Avatar
well darn guess I wont be any help to you. How are they different LOSTMY65 just curious never paid much attention
Old 01-02-2013, 01:06 AM   #5
LostMy65
LostMy65's Avatar
The width location of the bumper mounting holes is the same, but the vertical measurement is taller for both the mounting holes, and the frame.
Old 01-02-2013, 01:08 AM   #6
LostMy65
LostMy65's Avatar
here's a thread
http://67-72chevytrucks.com/vboard/s...d.php?t=536716
Old 01-02-2013, 11:38 AM   #7
JQ-72
JQ-72's Avatar
Thanks anyway, Travz. It does have to be a torsion bar frame from 1960-1962. Anyone else??
JQ
Old 01-02-2013, 04:00 PM   #8
travz500
travz500's Avatar
dont get worried yet my mother in law has a 62 I will see what I can get done she may sell it to me to part out not sure its not a complete anyhow missing most of front clip
Old 01-02-2013, 05:36 PM   #9
paulspickupparts
Travs500 may have you covered . I should have a set if it gets to me . I would have to check condition also but have three 60-62 trucks. Thanks
paulspickupparts is offline   Reply With Quote
Old 01-02-2013, 07:05 PM   #10
travz500
travz500's Avatar
ok better let paul fix you up talked her into parting with parts but the frame is even rusted in two up there some how but if you need other parts let me know thanks
Old 01-02-2013, 07:12 PM   #11
JQ-72
JQ-72's Avatar
You are up, Paul!!
Old 01-02-2013, 07:27 PM   #12
paulspickupparts
I will grab the snow shovel. How far back do you want them cut. Probably should throw a price so we are on the same page . $40 plus shipping . If less than 12 inches long should be able to get into a medium flat rate for $10.50.Thanks Paul
Old 01-03-2013, 10:55 PM   #13
paulspickupparts
Here are some pics of the frame horns I removed today. They are in good shape but do have two smal cracks by the tight bend. Would be an easy fix with wire feed. These came off two different trucks in order to get a good pair . Kind off odd they were cracked in the same spot.
Old 01-03-2013, 11:07 PM   #14
JQ-72
JQ-72's Avatar
So is it still around $50 shipped? PM your info and I'll get you some $$$. Thanks.
Joshua
Old 01-03-2013, 11:09 PM   #15
paulspickupparts
If thats ok with you . The cracks are really minor . Will send PM with info.
Old 01-03-2013, 11:23 PM   #16
paulspickupparts
Joshua, I just wrapped them up and was able to get them in a padded emvelope. You can make the total $46 instead of $50 . Thanks Paul
Old 01-08-2013, 06:06 PM   #17
paulspickupparts
Joshua, just to let you know the frame horns were sent today via USPS Priority Mail . PM has tracking # . Thanks again, Paul
Old 01-14-2013, 05:31 PM   #18
JQ-72
JQ-72's Avatar
Paul, I got the parts over the weekend. Thanks for your help!!
Joshua
Old 01-14-2013, 08:07 PM   #19
paulspickupparts
Thangs again, good luck with your truck. Paul
