Old 01-02-2013, 01:42 AM   #1
DBear
DBear's Avatar
swap compatibility?
Does anyone know if the axles off an 73-87 chevy 4x4 bolt up to a 1971 chevy 4x4? Looking at getting a dana 44 or 10-bolti to swap to the 1971 Burb. I need to know if the spring perches are the same distance apart??? Trying to find 3/4 ton axles with 4.10 gears to replace the 1/2-ton 3.07 axles. Thanks in advance!
DBear is offline   Reply With Quote
Old 01-02-2013, 09:27 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: swap compatibility?
Front is a direct swap, rear will probably need spring perch and shock mounts. As far as the D44 goes, there are big bearing and small bearing spindles, but you can swap 6 lug 1/2 ton to 8 lug 3/4 ton. Not sure if that works on the newer 10 bolts or what years the parts interchange. Early to mid 80s went from D44 to 10 bolt.
Rich
1972 K5 Blazer CST Click HERE
Old 01-02-2013, 10:30 AM   #3
72BBCK20
Front is a direct swap regardless if its 10bolt, d44 or d60. As for the rear the only direct swap will have to come from a 1 ton as the 73-87 1 ton spring perches are the same width as all 67-72's. however you will need to relocate the rear shock mounts.
72BBCK20 is offline   Reply With Quote
