Tire Question
I am currenty looking at a 29x15.5x15 sportsman tire. I have a 15x10 wheel with 5 inch backspacing will this fit under the rear of a 71 with just doing the wheel tubs in the bed?
Re: Tire Question
Not sure on whether it will fit the wheel well but with that 10" wheel you won't be able to take advantage of the 15.5 width. While the tire will mount on the 10" wheel a 12" will make a huge difference in getting all that whoop ass to the ground
Re: Tire Question
so if I do a 29x12 ill be fine? Or do I want a 30x12
Re: Tire Question
Lots of information can go into tire size. Engine (size, compression, heads, cam, intake, carb) transmission (stall?), gearing, etc if you want to get some power to the ground. There are lots of 10-12 second cars out there on 10" tires. If it's just to get a fatty tire look some of those may not matter so much. Sorry, but all this doesn't answer your original fitment question.
Re: Tire Question
more or less just going for the fatty tire look
Re: Tire Question
That's cool. Post up a pick when you get them on there!
Re: Tire Question
So should i do the 28x12 or the 29x15
![]() Join Date: Feb 2012
Re: Tire Question
29x12 will ride the best and you won't have to wind the motor up hard to cruise
1970 c-10 lwb named "heavy metal therapy" |
Re: Tire Question
the mickey thompso s/r I can only find a 29x15. Will this fit with a 5 inch backspacing
Re: Tire Question
I would look at Hoosier tire and see what they have to offer
