![]() Join Date: Apr 2010
Working AM/FM radio
This is a real truck AM/FM radio that is in working condition! All fuction work as they are suppose to. Slides from AM to FM smoothly, all presets buttons operate correctly, volume control works, and treble bass works. It works on both AM and FM bands. Now for the bad, someone has cut in back of the mounting knobs with a hach saw on both sides, I guess to make it fit into there vehicle. Once it is mounted into your truck it should not show. It also has the wrong lens that is siliconed into place and the slide from AM/FM has been siliconed back together but is operating as it should. The chrome has normal pitting. $275 shipped
![]() Join Date: Oct 2011
Re: Working AM/FM radio
nice for a "driver"
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
Carpe manana
![]() ![]() Join Date: Dec 2010
Interested but trying to see the cuts - where are these in the photos? Is the chassis of the radio cut? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Carpe manana
Les if the cuts are just to the top front corners and the slide bar is intact i.e in one piece (you said siliconed back together) I'll take it. Pete
In the last 2 pictures I tried to show where the cut was. The cut is on the face plate only directly behind the volume knob and the station set knob
Carpe manana
I see the cuts - If the slider bar isn't broken I'll take it. Do you happen to have mounting hardware to include?
There are 2 tabs on the back of the slide bar and 1 was broken off and that is why it was siliconed back together. You can buy new slide bars and lenses after market. Let me know if you still want the radio, thanks Les
The radio will come with mounting bracket on the back, mounting cups on the front and wire plug on the back
Carpe manana
I'll take it Les, thanks. Can you include the knobs as shown? The lenses are discontinued and not too easy to find but slide bars are available. Pete
Carpe manana
Payment sent
AM/FM radio has been SOLD to DeadheadNM, thanks
