01-02-2013, 11:50 AM | #1 |
Wiring Connectors?
I'm installing the new radio in my truck my wife gave me for Christmas.
So I've installed a lot of radios/connected a lot of wires over the years using the twist and tape method, plastic compression connectors, etc. I would like this to look a little better than my typical "get it done fast" job. So, I thought I'd throw this out. What is the best and most professional way to connect the wires to the speakers/truck? Any suggestions on connectors? Thanks, Scott
------ 65 Chevy C10 Fleetside |
01-02-2013, 12:30 PM | #2 |
"Where were you in '62?"
Re: Wiring Connectors?
I always use Butt Splice Connectors, Spade Terminals, Ring Terminals Connectors, Male/Female Bullet Connectors, and Heat Shrink Tubing.
http://www.jegs.com/webapp/wcs/store...=Connector+Kit http://www.jegs.com/webapp/wcs/store...+Shrink+Tubing Also check out: http://www.crutchfield.com/shopsearc...onnectors.html
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 01-02-2013 at 12:35 PM. |
01-02-2013, 12:55 PM | #3 |
I use inline butt connectors and heat shrink. You can use the non-insulated connectors when using heat shrink and the use wire loom to tie it all up.
Get a good set of lineman pliers if you don't have a set.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-03-2013, 01:34 AM | #4 |
60-66 Nut
If you want the absolute best connection, solder and shrink tube with the sealant inside. The next best would be the non-insulated connectors and shrink tube that jimmydean mentioned. You can also get the insulated crimp on connectors that have the heat shrink type insulation with the sealant.
01-03-2013, 09:41 AM | #5 |
Thanks for the suggestions! I went with insulated butt connectors. I will one day put a new wiring harness in the truck and when I do I'm going to do the solder and shrink tube for the connections.
The radio has bluetooth music streaming/handsfree phone and an HD tuner. It's going to be interesting to see if the callers can hear me over the roar of the truck. Truck is sounding good inside and out!
01-03-2013, 09:10 PM | #6 |
Who Me?
Thats the easiest way to go.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
