Dually roof lights
i have a 82 GMC 3500. i wanted to know if anyone sells clear lens for the roof lights, instead of amber. i always see new f350's with them, just wanted to see if anyone knew of a place that sells clear replacement lens that fit the stock location. Thanks, any info would be appreciated!
Re: Dually roof lights
lmc sells clears
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
Charlie Daniels w/ a Tq Wrench
The clears they sell are for the 88-2000 and 2001-2007 body style trucks. They do not sell clear lights in the "fireman's hat" style for this body style truck. To run the new lights would require new holes to be drilled. I don't think I have ever seen clear "fireman's hat" style lenses.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
ive seen the ones they have but they look aftermarket, mine have two bolts holding them on. one on each side. are there more on a different page? theres a couple different ones on page 77 but none look like the stock ones?
'82 c10 shortbed drag truck '82 GMC 3500 Dually DD scrap truck '55 Chevy 210 4 door sled '65 VW Bug Rat Rod |
ok Firemans hat style makes sense that what they look like lol but thanks, yea those are the style i need. someone should start making them! Thanks fot the info guys!
There is a clear lens that is a direct fit onto the "fireman's hat" base, it is not shaped the same, but is the same diameter and uses the same holes. The 67-72 Stepside reverse lights will fit in place, they look more like the 69/70 flat "hockey puck" style clearance lights, but are clear and are a direct swap. IIRC they require longer mounting screws though.
Here is a really old thread discussing the ones I mentioned
http://67-72chevytrucks.com/vboard/s...d.php?t=206764 They are labeled as reverse lights for a P30 step van in that thread, but I believe the exact same lenses were used on stepsides as well.
kool, those dont look bad at all. i might look into getting some! Thanks!
