01-02-2013, 05:57 PM | #1 |
rear tire/rim width
Hello Friends, how wide a tire/rim can I put on my 76 c10 shortbed. I want to put as wide a tire as possible without having to alter the rear axle. I do not mind having to put in new wheel tubs to accomidate a larger set of wheels because I have got to put a new bottom in the bed anyways. Thanks for all the help.
01-02-2013, 06:00 PM | #2 |
Re: rear tire/rim width
without having to get new tubs for your truck you can run up to a 15-20x10 wide rim if you go any bigger you will have to tube it more. being that I dont know your rim size thats why I used the 15-20
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
01-02-2013, 10:36 PM | #3 |
I havent done it myself but Ive been told that you can put a 15x12, 7.5in backspace, and a 29-15.5x15 tire. Its a very tight fit with no rear/suspension mods but you will need to widen the wheel tubs and maybe trim fender lip slightly.
John 82 Chevy Silverado 350ci/TH350 |
01-02-2013, 10:53 PM | #4 | |
I would love to see photo's if it indeed true that you can do that, not that I'm going to but I think it would be interesting to see some pictures if it has been done successfully.
01-03-2013, 09:41 AM | #5 |
I am running a 20" x 10" with a 285/50/20 on my rear with no mods. I have enough room to fit one finger between the tire and the tub.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
01-07-2013, 03:18 PM | #6 |
I run a 10 in. Rim with a 315/35/20 with plenty of room.
Posted via Mobile Device |
01-07-2013, 07:28 PM | #7 |
Go Hard or Go Home!
On my 75, I'm running Cragar street lights, 10" with Mickey Thompson 29 x 12.5 x 15 sportsman on the rear. I have a 4" drop in the rear, the fender lip is close but so far i've never shredded a tire............
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. Some day's, it's just not worth chewing through the restraints................................ |
01-07-2013, 08:11 PM | #8 |
1985 C10 2004 Avalanche |
