steering stablizer kit
does anyone have one of these kits on their truck ,are they worth the money and do they work
Re: steering stablizer kit
On a 4x4 with big tires it helps on a 2wd its just a band aid for wore out parts.
i dont have worn out parts but i do have some bump steer
needs more $$$
Isn't bumpsteer caused by poor geometry? If we are talking about the truck in your avatar...what was used to lower it? Just springs? If so, I'd swap to a spindle/spring combo to get that ride height. I never noticed any bump steer in my blazer with a 4" drop using a spindle/spring combo.
1970 2wd Blazer |
I am pretty sure it was done with springs only.the spindles don't look like drop spindles more stock .
the truck was done in the US before the myself and the guy i bought it off. he knew nothing about what had been done so i have been trying to figure it all out. i have 18 months till i retire early then i was going to redo the suspension properly that way i know what is under me. the bump steer is'nt that bad its just that i saw the stablizer while i was looking thru the LMC catalogue. thanks for your help |
I was looking hard for bump steer tie rod ends for you but no one makes them.If you get time take a picture of the spindles you have just take the wheels off.We can tell if you have drop spindles or not.
