Old 01-03-2013, 08:17 PM   #1
1972 Jimmy
1972 Jimmy's Avatar
1972 Jimmy 4wd Small hub or Big hub?
Have a question for you guys.... Started my winter project tearing apart the axles on my 1972 jimmy. The front axle looks to be the original Dana 44 however some previous owner swapped one of the spindle/hub assemblies. So, I have one large bearing spindle and one small......So the question I have is which one is original and second which is stronger. I'm assuming that the smaller is original and the larger in newer???? Also, which one is better??? Can any one help???
1972 Jimmy is offline   Reply With Quote
Old 01-04-2013, 01:20 PM   #2
SeventyOne
Re: 1972 Jimmy 4wd Small hub or Big hub?
Smaller spindle is original - larger is newer and uses larger wheel bearings which would make it stronger.
8-lug Dana 44s use the larger spindle but no reason it can't be 6-lug.
SeventyOne is offline   Reply With Quote
Old 01-04-2013, 07:30 PM   #3
1972 Jimmy
1972 Jimmy's Avatar
Thank you for the reply. Looks like I'm going to shop around for larger bearing spindle and hub tonight!!!!
Old 01-06-2013, 11:17 PM   #4
hilljob26
hilljob26's Avatar
if you cant find an extra large, i have an extra small that im not using
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
