![]() Join Date: Jan 2012
Is this suppose to happen
My belts did not line up so I was doing some investigating as to why? I know i have a short shaft on the w/p, but i have 4 pully spots on the c/s pulley. I pulled it off to find out that they shimmed it with washers. Then i wanted to clean up the harmonic balancer and woops!
Re: Is this suppose to happen
That's actually fairly common. The rubber that holds the balancer together will deteriorate over time and come apart. At least it did it now and not while you were driving down the road!
-Scott- |
![]() Join Date: Aug 2008
Wow! I have never seen one that bad, though!
Posted via Mobile Device |
Can i use a 350 balancer on the 307. I know it will fit the shaft and seal, but what will the 8 in dia. and the weight effect?
Ive seen the one on my 83 wobble but it didnt fall off
i had two come off one my 307 in my nova both while driving. damn junkyard parts lol
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I had one on my 89 K30 454 slip to the rear and chewed a hole in the oil pan 200 miles from home. That was an expensive night.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
They are both internally balanced so it won't be a problem. The only problem you might have is the timing tab.
Tommy 1 Pt. 3:21 '72 C10 LWB 402 |
