01-03-2013, 10:40 PM | #1 |
3.21 gears in a 14 bolt
I recently parted out my grandpa's all original 61k mile 1980 Chevy K20. I was expecting to see 4.10s in the axles as no optional ratio was listed on the spid. Needless to say I was quite surprised to see 3.21s instead. This is the first one I have ever seen, how common were they?
4.10s on left, 3.21 right
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
01-04-2013, 12:08 AM | #2 |
Re: 3.21 gears in a 14 bolt
Not to common as I have to find a set for my truck. I am half hearted looking though. They would likely be more common in delivery vans like the D61 if my research is true.
From what I see 3.73, and 4.11 are the most common in the 14 bolt. |
01-04-2013, 01:12 AM | #3 |
I have one in my 86 2wd 3/4 crew cab
01-04-2013, 05:46 PM | #4 | |
01-06-2013, 09:53 AM | #5 |
My 83 C20 454 Suburban has them...I was surprised to find them also! The tow ratings for my truck jump quite a bit from 3.21 gears, to 3.73 gears, to 4.10 gears!
12-21-2015, 11:52 AM | #6 |
I know this is an ancient thread but I sure am jealous, I'd even be happy with a 3.73... my truck certainly doesn't enjoy freeway.
Any suggestions on where to find taller geared 14FF?
1973 C20, 350/350 |
12-21-2015, 12:35 PM | #7 |
I always seemed to find the 3.42s in Suburbans. The trucks were more 3.73s and 4.10s. I am in the midst of trying to convert mine from 4.56s to 3.73s. I having more trouble finding reasonable 3.73s for the Dana 60 than I did the 14 bolt.
12-21-2015, 12:54 PM | #8 |
If you're in the Bay Area let me know if you find a 14FF with 3.73s in it, especially if it has the G80 locker (I have a C20, not a rock crawler, so I'd prefer a streetable locker even if it isn't quite as strong as something aftermarket). 4.56... wow, with normal tire sizes your truck must scream on the freeway.
1973 C20, 350/350 |
12-21-2015, 02:25 PM | #9 | |
My 79 1 ton has 3.73's and with it's original tire size of 9.5 x 16.5 they are listed at 30.5" tall. It'll cruise easily at 65-70 mph at about 27-2800 rpm. The 454 runs perfect like this, I've criss crossed the country like this a couple of times going more than 2,000 miles with it and knock down 14 mpg doing it. A couple of my other cars also have 3.73's with 28" tires and they cruise along at 65mph pretty easily as well. I just don't get in a big hurry. 65-70-ish is all I care to go anyway. |
12-21-2015, 02:26 PM | #10 |
Yeah I noticed that too, identical trucks and tow ratings increase when they have more gear in them. Makes sense.
12-22-2015, 12:16 AM | #11 | |
At this point it'll spin a tire off the line with a utility bed full of tools, I'd rather have it do better on the freeway instead. 3.73 probably makes more sense than any taller than that, it's almost exactly a 10% difference and I'd be surprised if I could fit 34s without rubbing which would do the same to gearing.
1973 C20, 350/350 |
12-23-2015, 11:26 PM | #12 |
Here is the picture again, I do want to mention that with a stock 350 and short 30" tires, the truck was a dog. Notice how thin the 3.21 ring gear is compared to the 4.10.
12-23-2015, 11:34 PM | #13 |
Those gears are out there.
I found a set on evil bay awhile ago. you just have to keep and eyeout and get lucky. |
08-08-2017, 08:59 PM | #14 |
You'll find these commonly in 2wd 3/4 ton Suburbans and crewcabs. My '80 C20 Sub came with them. I found out when i installed an aftemarket tach and punched in the specs into an RPM calculator. If your motor has decent TORQUE, (400 lb ft +) you'll move these tall gears with 33's no problem all the while having decent lower highway revs. (1800 @ 60 mph)
*UNDER CONSTRUCTION* '80 Suburban C20 (C6P) (Silverado) - '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior |
